ᐅ Designing and Sturdily Building IKEA Metod Kitchen Islands Yourself with Plenty of Storage Space
Created on: 8 Nov 2023 09:42
jupote
I am currently planning an IKEA Metod kitchen island and want to build it as sturdy as possible while maximizing storage space. The idea is for the island to serve not only as a central work surface but also to provide plenty of room for pots, pans, and supplies. I want to combine the standard modules effectively and possibly add some extras to ensure everything holds well and the structure is robust – especially since I plan to use countertops made of thicker material.
Does anyone have experience designing such islands, particularly with regard to stability and optimizing storage? Are there any tips for additional reinforcements or smart combinations of the Metod base cabinets?
I look forward to your input and also any advice on common mistakes to avoid.
Nabla64
9 Nov 2023 16:02
Layla schrieb:
For example, I reinforced the back panels with extra boards, which gives a really solid feeling.
Exactly, reinforcing the back panels is a very effective step. Especially when you use solid furniture backs instead of glass panels, it significantly improves stability.
Another tip: If you are planning to install electrical appliances in the island, consider cable management – holes in specific areas of the back panels can also be used for reinforcement if fitted precisely with metal frames or trims.
I also recommend fastening the countertop not only along the edges but also in the middle section to prevent sagging. This is often underestimated in kitchen islands, especially if they are larger than 1.5 meters (5 feet).
