ᐅ New Build: About 280 m² Plus Basement – Your Suggestions
Created on: 15 Jan 2021 13:06
Pfalzpaulianer
Thank you again for your suggestions and feedback on our initial draft. The architect has put in a lot of effort, and we are now almost ready to submit the building permit / planning permission application. Here is the nearly final version. We appreciate your opinions, thoughts, and suggestions.
Attached is the questionnaire
Development plan / restrictions: Paragraph 34, according to neighboring buildings
Plot size: 709 sqm (currently with an old structure - demolition in progress)
Slope: no
Floor area ratio (FAR): n.a.
Site coverage ratio: n.a.
Building setback, building line, and plot boundaries: 3 m (10 feet)
Edge development
Number of storeys: 2
Roof style: gable roof
Architectural style: modern house with classic Palatinate elements (wooden tile roof, sandstone features, shutters)
Orientation: south
Maximum height / limits: according to neighboring buildings
Homeowners’ requirements: The wonderful view of the vineyards (to the north) should be considered in the floor plan.
Style, roof shape, building type: Since our plot is located in a wine village, we want a new building with classic Palatinate style elements, but without looking kitschy or outdated.
Basement, floors (full or partial basement, 2 full floors plus attic)
Number of occupants, age: 5 (41, 40, and 3 children aged 13, 9, 9)
Space requirements on ground and upper floors: Large living and dining area on the ground floor (space for a piano), bathroom and TV room on the ground floor (can also serve as a bedroom for possible care needs of relatives)
1st floor: parents’ area including dressing room and bathroom, man’s home office, guest room / office
2nd floor: children’s area with 3 bedrooms and children’s bathroom
Office: family use or home office: two home offices
Number of overnight guests per year: 10
Conservative or modern design: mix
Open kitchen, kitchen island
Number of dining seats: 12
Fireplace: yes, Swedish round-tiled stove
Music / stereo wall: no, TV room on 1st floor (guest room)
Balcony, roof terrace: roof terrace above double garage with vineyard view
Planned by: architect
What do you particularly like? Why? Separate parents’ and children’s areas, roof terrace with a wonderful view of the vineyards also from the home office, separate TV room, open kitchen with spacious living and dining area, seating area in the gallery on 1st and 2nd floors
What do you not like? Why? Window sizes on the 1st floor still need final planning, probably slightly larger. We do not really like the round windows (extension and north side). Do you have alternative ideas that would suit the house?
Estimated price according to architect/planner: initial estimate about 900,000 including additional costs (excluding garden)
Personal price limit for house including fittings: 900,000
Preferred heating technology: heat pump with cooling function
[If you had to compromise, on which details / fittings? Full basement (this is a cost issue because the current house has a basement and must be demolished; a partial basement is planned, and depending on the cost of backfilling, a full basement might also be an option.)
- Could you go without: large master bedroom, children’s bathroom in the attic can be smaller
- Could not go without: children’s floor with children’s bathroom, roof terrace, large dressing room
Why has the design turned out as it is? Many discussions with the architect. It is important to us that the house does not look standard from the outside. More expensive, but planned for that. For example, shutters and sandstone elements.
Which wishes were implemented by the architect? Separate parents’ and children’s areas
Great: separate areas, spacious living and dining room
Children’s bathroom with separate toilet to reduce morning congestion for the three schoolchildren?
Ideas for exterior views?
Enjoy looking through this, and thank you very much for your help.
Floor plan of a residential house with living room, kitchen, dining area, garage and garden
Upper floor plan: gallery, corridor, master bedroom, guest room, office, bathroom, roof terrace.
Attic floor plan with three children’s bedrooms, bathroom, corridor, gallery, stairs and balcony.
Floor plan of a house with garden, trees and plot boundary.
Section through a multi-storey residential building basement to attic with staircases, roof structure; A-A
North elevation of a house with garage, terrace and dormers.
East elevation of a multi-storey house with gable roof, windows and trees; a person.
South elevation of a two-story house with dormers, terrace and people.
Architectural drawing: two-story house with balcony, terrace, side extension, trees, west elevation
17 Jan 2021 11:01
Hausbautraum20 schrieb:
But at 900k, the extra 20k for the additional spacious area is simply worth it.
Combined with the upper floor, that adds up to more than €50,000, which means the 900,000€ budget will be sufficient.
SchaeffnS
17 Jan 2021 11:24
Pfalzpaulianer schrieb:
We have been going back and forth about the porthole window the whole time. What would you suggest?
For me, the front door would be wider, so the two small windows next to the door would be removed, which creates a cleaner look and still allows light in.
As for the upper windows, since they open towards the gallery anyway, I would choose floor-to-ceiling windows and extend them as high as possible, removing the porthole. If shutters are a must for you, then try testing without window muntins or arches, and maybe size them a bit larger.
Pfalzpaulianer
17 Jan 2021 14:52
SchaeffnS schrieb:
For me, the front door would be wider, so the two small windows next to the door would be removed, creating a calmer visual appearance while still allowing light in. The upper windows, since they lead to the gallery anyway, I would make floor-to-ceiling and extend them as high as possible, removing the round window. If you must have shutters, then try them without window bars or arches, and maybe make them slightly larger.
We will build the front door as double-leaf (is that the right term?). We had the exact same discussion. The architect likes the so-called "starvation windows," but we don’t. What would you choose instead of the round window? We do need one at the top for the gallery. On the south side, we should have the same shape in the gable. Thanks for your feedback. Very helpful.
Pfalzpaulianer
17 Jan 2021 14:58
Added together with the upper floor, that amounts to more than €50,000... so that the €900,000 will be sufficient.
Thank you very much for the detailed discussion, but downsizing is not an option for us. We are satisfied with the size, and even the calculated €50k is worth it to us. Especially since, as I said, this change would be missing on all floors. Honestly, we’re not investing such a large amount just to compromise on every floor. We would regret every day not having invested the approximately €50k.
PS: Sorry for the missing umlauts, but I don’t have a German keyboard 🙁
K1300S17 Jan 2021 16:10
That is exactly the job of a capable architect: to implement your wishes efficiently—that is, without compromises and still cost-optimized. Even if you are in the comfortable position of not having to watch a budget of 50,000 EUR, it is still simply wasted money. There may be reasons that require a certain floor area, but a lot of free and poorly or unusable space is certainly not one of them. Aside from that, I’m sure you will find enough opportunities to spend money unnecessarily as the construction progresses. 😉
Pfalzpaulianer
17 Jan 2021 16:16
K1300S schrieb:
That is precisely the job of a skilled architect: to implement your wishes efficiently, meaning without compromises and still cost-optimized. Even if you are in the comfortable position of not having to worry about 50,000 EUR, that is just money thrown away. There may be reasons that require a certain floor area, but a lot of free and poorly or unusable space is certainly not one of them. Besides, I’m sure you will find plenty of opportunities to waste money unnecessarily as the construction progresses. 😉
I respect your opinion, but for us, it is not pointless—it is very valuable to have this space and thus the sense of roominess. As the saying goes, we agree to disagree 🙂 Thank you very much anyway.
