ᐅ My pet sleeps in the Kallax shelving unit – how do you protect the wood?
Created on: 4 Feb 2024 19:37
BolitauHello everyone,
I have a small but important topic for me: my pet – more specifically my cat – often and gladly sleeps in one of the compartments of my Kallax shelf unit. The wood is coated white, but I’ve noticed scratches and discoloration appearing where she spends the most time. Now I’m wondering how you protect your Kallax shelves or other wooden furniture when your pets make themselves comfortable on them?
I’m especially interested in which surface sealants have proven effective. Do you use special protective films, treat the wood with waxes or oils – and if so, which ones exactly? Also, how durable are these surface treatments when the pet lies or scratches on the furniture frequently?
I would appreciate any experiences, product tips, and perhaps advice on common mistakes to avoid.
Thanks in advance!
Thanks in advance!
From my experience, it is particularly effective to use a combination of protective film and regular maintenance.
For a Kallax shelf, which is often coated, I advise against oils or waxes, as these can alter the surface and potentially cause stains. Instead, I recommend using custom-cut, transparent PVC protective films that can be applied to the shelf surfaces. These are relatively unobtrusive and highly resistant to scratches.
Regular cleaning with a mild detergent also helps prevent dirt buildup, which can cause damage over time.
I will go into a bit more technical detail: Kallax furniture is usually coated with a melamine resin surface, which is fairly resistant to scratches and stains but does not provide a completely scratch-proof finish. If your cat frequently sleeps there and uses its claws, micro-damages will occur that become noticeable over time.
Here are your options:
1. Protective film: Thin PVC or polyurethane films designed specifically for furniture can be applied to the individual compartments. It is important that the film has a non-aggressive adhesive layer so it can be removed later without leaving residues.
2. Surface sealing: Wood oils or varnishes are not recommended for Kallax, as it generally has a HPL or melamine resin surface. While varnish would offer protection, it might dull the surface or cause adhesion problems.
3. Cushions or inserts: As an alternative, you can have custom-made cushions or inserts covered with fabric. This completely prevents scratches and offers your cat a more comfortable resting place.
One more question: How intensively does your cat use the Kallax compartments? Does it only use it as a sleeping spot, or does it also actively scratch there?
Filippo schrieb:
One more question: How much does your cat use the Kallax compartments? Does it use them only as a sleeping spot, or does it actively scratch on them as well?Thanks for the detailed information! To answer your question: She mainly uses it as a sleeping spot, so she lies inside and retreats there. She does scratch occasionally, for example when climbing in and out, but generally uses the designated scratching boards. The damage seems to be caused more by lying there and occasional movement with claws rather than intensive scratching.
I had suspected that a lacquer finish might not be ideal there—good to know. Cushions or inserts are an interesting idea, thanks for the tip!
Hey, that sounds really cute – your kitty in the Kallax 😄
From what I can see, a combination of soft padded inserts and a scratch-resistant film might work best. Especially films with slightly textured surfaces feel less slippery for cats, and if they scratch, it won’t cause much damage.
If you use cushions, make sure they are washable – little cat hair nightmare situations happen now and then 😉
Important: avoid oily products, as cats might lick them, which wouldn’t be good for them – so rather use safe, non-toxic materials. 🙂
