ᐅ My KALLAX is staining – is that normal?
Created on: 18 May 2015 08:07
Lojula
I have a white IKEA KALLAX shelving unit in my apartment, and recently I noticed that when I wipe it with a light-colored cloth, some color comes off from the shelf. My question is: Is it normal for a KALLAX unit—especially in white—to transfer color like this? I have already tried gently wiping it with a damp cloth, but the result remains.
I make sure not to use any harsh cleaning products, and the shelf is neither very old nor damaged. I’m curious whether this might be a production-related issue or if I possibly received a defective product. Maybe others here have had similar experiences?
Thanks in advance for your assessments and tips!
BauSimon
19 May 2015 08:05
here is a brief overview of how to handle color transfer issues with KALLAX shelves:
1. Check the cause: The surface seal might be inadequate, or there could be wear and tear damage.
2. Minor scuffs can be fixed by applying a clear acrylic lacquer or furniture sealant. Important: test on an inconspicuous area before use.
3. If the shelf is new and color transfer occurs despite careful use, you should initiate a claim with IKEA. They are usually reasonable in such cases.
4. To prevent issues: avoid cleaning furniture with excessive moisture, do not use harsh chemicals, only mild cleaning agents.
Summary: Color transfer is not necessarily normal and usually indicates a problem with the plastic coating. Re-treatment or replacement is advisable.
nedagla
19 May 2015 11:27
YES, great thread here!! 🙂
I had the same issue with another white shelf, but the discoloration completely disappeared after applying a coat of paint sealant. Just look for a matte clear coat at a hardware store – that’s really the easiest solution!
Don’t give up, you’ve got this! 🙂
CHRISTOP33
20 May 2015 09:14
Hi Lojula,
[Farbabrieb beim KALLAX? Nicht gerade das, was man sich wünscht! 😅]
Color transfer is definitely annoying, but it’s not the end of the world. If you don’t consider the shelf “cursed” yet 😉, a clear protective varnish or sealant might save it.
Sometimes the white paint isn’t thick and durable like ivory but rather a very thin layer that gets damaged by friction. So, no need to panic! If the problem doesn’t improve or spreads, definitely consider returning it.
Good luck! 🙂
