ᐅ Multi-generational house with an underground garage for three families
Created on: 11 Mar 2019 09:55
Muc1985
After reading quietly for a while and really appreciating all the ideas shared here, I’d like to bring up a topic and hopefully get some feedback, suggestions, and ideas!
I am 34 years old and originally from Munich, where I was born and raised.
Currently, we (my wife and I, with a child on the way, my sister and her partner, as well as my parents) are discussing whether to completely rebuild on our plot of land (currently occupied by a single-family house / 1000 sqm (0.25 acres) / 20 × 50 m (65 × 164 ft) / no zoning plan). The idea is to build a fairly modern house with two spacious living areas (each with its own terrace overlooking the garden, large living and dining areas, etc., and about 200 sqm (2150 sq ft) of living space), including an underground garage and a basement. A granny flat (or accessory dwelling unit) is also planned to be integrated.
I would like to start a discussion based on these ideas and am looking forward to any input or constructive criticism.
Thank you very much.
kaho67418 Mar 2019 13:20
I like the design, but I can't imagine that it will be approved given the neighboring buildings. It’s quite a hefty structure.
Muc1985
18 Mar 2019 13:31
kaho674 schrieb:
Not wider, but deeper.
Exactly!
@kbt09, thanks for "starting the conversation."
kbt09
18 Mar 2019 21:25
The house for Family 2 is already about 9m (30 feet) deep... I can't see the graphic right now, as I'm on the go. There should also be space left for a 3-4m (10-13 feet) terrace facing southwest and a 3m (10 feet) setback from the property boundary.
Yes, it’s a huge building, and it doesn’t even include the 2 x 200 sqm (2 x 2,150 sq ft) for Families 1 and 2. I just wanted to show how much floor area is being used up.
11ant18 Mar 2019 21:51
kbt09 schrieb:
And I just wanted to show how much floor area is actually being used.
You demonstrated what such a building volume can look like – this gives the participants something tangible to work with. That’s all that’s needed for now – “it’s fine as is.”
kbt09 schrieb:
and it doesn’t even include the 2 x 200 sqm for families 1 and 2.
That’s not necessary either: it’s not too small, so I wouldn’t put too much emphasis on nominal square meters. More isn’t possible anyway, rather less: from my perspective, your design almost fully utilizes the available building mass, which means that, relative to the neighboring environment, it would already be quite substantial.
Muc1985
19 Mar 2019 08:09
Personally, I really like the floor plan of Family 1. It’s more or less what I had in mind. For Family 2, I also find the initial ideas quite successful. My only comment here would be regarding the width of the house; in my opinion, there is potential for more space.
I need to correct my previous statement because I mixed up Family 1 and Family 2. Therefore, I see room for improvement in the depth (not the width) of the house for Family 1. Otherwise, the concepts are truly well designed, and now you can clearly visualize the layout. I will continue to contribute detailed feedback on this topic and am already in contact with kbt09.
11ant19 Mar 2019 17:05
Just to be a bit of a party pooper: have you already checked whether the local authority might actually have a specific idea of a practical building envelope like the one below?
Site plan of a plot with blue building area and surrounding buildings
