ᐅ How to Securely and Stably Mount IKEA Metod Kitchen Cabinets on Drywall Panels
Created on: 13 Apr 2020 18:07
BEJE4Hello everyone,
I am currently planning to install an IKEA Metod kitchen in my apartment, but the walls are covered with drywall (gypsum board), which might pose a challenge for mounting the kitchen cabinets.
My specific question is: What is the most secure and stable way to attach IKEA Metod kitchen cabinets to drywall walls so they can support heavy loads without the installation becoming unstable or the cabinets eventually falling down?
I want to be absolutely sure about this since the kitchen cabinets need to bear significant weight as well as dynamic loads from opening and closing.
Has anyone had experience with special anchors, fastening techniques, or possibly installing wooden battens behind the drywall?
What options and approaches are advisable when there is no load-bearing wall behind the drywall?
I look forward to your detailed tips and experiences!
I don’t want to spoil the fun, but I see it a bit differently.
Even with the best specialized anchors, a drywall-only wall is unlikely to hold the weight reliably over time. It’s important to remember that gypsum plasterboard panels are not load-bearing walls but rather cladding.
The only truly secure method is to create a load-bearing substructure, such as wooden battens or metal profiles inside the wall, or to support the cabinets from the ceiling or floor.
Many people today overestimate what anchors can do just because they are designed for hollow walls. The problem is that the weight continuously pulls on these attachments, which is very different from a short-term load.
For an IKEA Metod kitchen, especially if there is a lot of storage, I would definitely not rely solely on drywall anchors.
BEJE4 schrieb:
How can IKEA Metod kitchen cabinets be mounted most securely and safely onto drywall so that they can carry heavy loads without the installation becoming unstable or the cabinets eventually falling down?
Hello BEJE4,
I can understand your question well; the topic of fastening to drywall is indeed not straightforward.
I agree with this, but I would like to add a few points.
- It is important that the load is ideally transferred to the supporting wall behind. This means that if the drywall is directly in front of a solid wall or load-bearing wall, the screws should be anchored there. If this is not the case, installing additional wooden battens or special mounting panels can be useful.
- If you install wooden strips behind the drywall, you can use them as a load-bearing base for the wall cabinets and distribute the weight across these strips. However, very precise and sturdy workmanship is essential here.
- In the case of a purely hollow cavity (e.g., metal profiles) without a load-bearing substructure, I recommend high-quality metal cavity anchors that can support significant weight. Keep in mind that for cabinets with dynamic loads (opening and closing), the stress is often higher than the static weight of the cabinets.
My advice: Before installation, always carefully check where the substructure is located, if necessary using a cable detector or multi-detector, and try to use multiple fastening points for heavy cabinets.
If possible, a combination of substructure and anchors can ensure the best stability.
GEKAU51 schrieb:
The only truly reliable method is to either create a solid substructure, like wooden battens or metal profiles inside the wall, or to support the cabinets from the ceiling or floor.
praWarre6915 Apr 2020 12:21Hello,
I also mounted my IKEA Metod cabinets on drywall and can say from experience: it is definitely possible to achieve a solid and stable installation if you keep a few things in mind.
- First of all, it’s important not to rely on just one anchor, but to distribute the load across several points.
- Additionally, I installed a sturdy wooden batten inside the cavity behind the drywall, securely fastened to the structural wall behind it with proper screws. This batten then carries the entire weight of the cabinets.
I can say: yes, that idea is great!
- The quality of the wooden batten is crucial, as is its secure anchoring to a load-bearing element.
- I then screwed the cabinets directly onto this batten, effectively creating a support structure that reliably takes the weight.
- The advantage is that the drywall itself doesn’t have to bear any load, only the support structure does.
And most importantly: since you want to be on the safe side, I also recommend paying close attention to the screw length and suitable anchors. For drywall construction, special heavy-duty anchors are suitable, but these alone cannot permanently support a wood kitchen unit.
I would say: better safe than sorry — it’s worth investing the extra effort in a reliable substructure to ensure peace of mind for years to come.
Good luck with the installation!
BEJE4 schrieb:
Does anyone have experience with special anchors, fastening techniques, or possibly installing wooden battens behind the drywall?
