ᐅ How can I install IKEA Metod cabinet doors to minimize noise?
Created on: 9 Nov 2024 08:37
gotyrese
I recently assembled an Ikea Metod kitchen cabinet and am now attaching the doors. I've noticed that when closing the doors, there is a relatively loud rattling noise. My specific question is: How can I install Ikea Metod doors to ensure the closing is as quiet as possible?
I suspect the issue might be related to the hinges or the way the doors are mounted, but the Ikea instructions do not address this specifically.
Does anyone have tips on how to reduce noise later on, possibly through special adjustments, dampers, or additional materials?
I would appreciate any helpful advice, including how to adjust the doors or prevent vibrations.
gotyrese schrieb:
Is there a recommendation on how much force should roughly be applied, especially on thinner metal sheets or connection points?Hello,
when assembling the Metod doors, sensitivity rather than brute force is required. A torque wrench is not strictly necessary, as the screws are designed for manual tightening.
It is important that the screws are secure but not overtightened. For wood or particleboard materials, it is advisable to tighten the screws until resistance is felt, then give only a slight additional turn.
Regarding your second question: yes, attaching narrow foam strips or rubber buffers at contact points effectively reduces vibrations and is a proven method to minimize noise. However, you should ensure that this does not affect the door’s alignment.
I recommend using flexible, self-adhesive strips that compress by a few millimeters (inches) to provide damping without altering the fit.
It’s interesting that everyone here only mentions the hinges and dampers, but hardly anyone addresses the main issue: IKEA furniture is often made from cost-effective materials that tend to warp over time.
Adjusting the doors helps little if the front panel itself isn’t stable. My advice: if you want truly silent closing in the long run, you should consider using more robust door fronts or adding extra reinforcements.
With Metod, there are certainly many ways to optimize, but real professionals invest in better hinges or install slats inside the doors—something that is often overlooked.
GALEO4 schrieb:
It’s interesting that everyone here only mentions the hinges and dampers, but hardly anyone addresses the main issue: IKEA furniture is often made from low-cost materials that tend to warp over time.That’s a very good point. From my experience, the material isn’t as durable as solid wood, but with proper care (storing it not too damp, etc.), you can prevent warping.
What I’m curious about is: What kind of additional reinforcements would you recommend? Special brackets, battens, or other constructions?
I’d prefer to keep my own woodworking effort to a minimum, ideally something compatible with the Metod system.
GALEO4 schrieb:
My advice: If you really want silent closing, you should consider long-term whether to use more robust door fronts or additional reinforcements.I agree, but to add to the topic: With Metod, it is often possible to screw so-called reinforcement profiles (aluminum strips or wooden strips) on the inside instead of the regular fronts. This significantly increases the stiffness of the doors without changing their visible appearance.
Additionally, you can glue custom-made strips into the frame that stabilize the door panel and, combined with damping pads, enable a much improved closing behavior.
If that is not desired, properly adjusted soft-close hinges with silicone bumpers on the door edges and internal rubber buffers can also help prevent continuous rattling.
gotyrese schrieb:
What kind of additional reinforcements would you recommend? Special brackets, strips, or other constructions?If you have the DIY skills, I would suggest gluing thin wooden strips or aluminum profiles to the inside of the door. This adds stability and helps prevent warping.
If you prefer not to do extra carpentry work, you can alternatively use the original Ikea system reinforcements available as accessories. Self-adhesive foam strips applied to the hinges and edges are also very effective at reducing vibrations.
Additionally, using mounting brackets screwed inside the cabinet is worthwhile if the structure doesn’t feel sturdy enough.
