ᐅ What to consider when choosing a mirrored cabinet and a vanity unit?
Created on: 23 Feb 2023 13:52
FrankChief
we are looking for a mirrored cabinet that suits our needs.
What should we consider?
How wide should the mirrored cabinet be? As wide as the sink or wider?
How high should the mirrored cabinet be? We can only install the bottom edge of the mirrored cabinet at 150cm (59 inches) because we have a plinth at 120cm (47 inches) where the sink is mounted, and under the mirrored cabinet on the plinth there is still space to place items.
We have Laufen VAL 75 (bathroom) and Laufen Pro S 45 (toilet). A mirrored cabinet should be installed above both sinks.
Which vanity cabinet would you recommend? The vanity should definitely have a black handle or be handleless (push-to-close), as we have black faucets from Grohe.
So far, we have found the following brands:
Badselekt
Sanipa
The original Laufen does not have black handles.
Tolentino1 Mar 2023 12:40
I’m not sure if it requires any special talent, but my wife managed to do it.
If you don’t succeed the first time, I can ask you again.
It might just be sunbathing, but then the current manufacturer who assembles these will probably sell similar handles with the same spacing through other channels.
Are you actually sure that the handles will be delivered pre-assembled?
They might just be included separately at first, and the holes will need to be drilled. In that case, you would be completely free anyway...
Jurassic135
1 Mar 2023 18:01
Just order the cabinet you want and see how it goes. Maybe, as Tolentino mentioned, the handles aren't even pre-drilled. I also spend a lot of time thinking about things like the interior, but sometimes it's better to just take decisive action and give it a try. It’s not a big deal, so I wouldn’t spend too much mental energy on it.
