ᐅ Labeling Furniture for Moving – How Did You Do It?
Created on: 27 Sep 2020 11:47
kati1337
kati133727 Sep 2020 11:47
we are currently thinking about how to label our furniture to show which room it belongs to. We will prepare floor plans of the ground floor and first floor for the movers, indicating the rooms and where each piece of furniture should be set up. However, we would also like to label the individual pieces of furniture themselves with notes about the room they belong to. I believe this would make it easier for the movers than constantly having to look at a separate list and figure out exactly which cabinet is which.
How have you attached such labels without damaging the furniture?
Maybe I’m missing something, but the only thing I can think of are Post-It notes. They definitely wouldn’t damage anything but don’t stick very well.
Any kind of label that sticks better risks either leaving part of the label stuck to the furniture when removed, or taking some of the furniture’s finish off along with the label.
chamäleon
27 Sep 2020 11:51
For example, search on well-known online retail platforms for "removable labels." You will surely find something. During our last move, we protected many cabinet fronts with cardboard or bubble wrap and attached notes using parcel tape.
FloHB123
27 Sep 2020 11:59
Are you not going to be present during the move? Otherwise, that would be too much effort for me. I would just label the boxes. The movers are not stupid and should know which room most of the large furniture belongs to. You will have to tell them anyway exactly where the items should go.
Pinky030127 Sep 2020 12:19
As far as I know, movers usually wrap the furniture in protective film to prevent damage. In that case, any markings on the furniture won’t be visible anymore.
Label your moving boxes, and you can use different colors for easier identification. For example, label the room doors in the new house. At least one of you will be present during the move, right? Then you can simply tell the movers where each item should go.
For our Pax wardrobes and doors, I covered them with masking tape and numbered them so the installer would know exactly how to assemble them.
kati133727 Sep 2020 12:38
Pinky0301 schrieb:
As far as I know, movers usually wrap the furniture in protective plastic film. That means any markings on the furniture won’t be visible anymore.
Label the moving boxes, and you can also use different colors. For example, label the room doors in the new house. At least one of you will be there during the move, right? Then you just tell the movers where each item goes.
We labeled our Pax wardrobes and doors with masking tape and numbered them so the assembler knew exactly how to set them up.
Yes, we’ll be there. Maybe I’m just overthinking it. Last time, the crew was incredibly fast, but it should be fine. They probably know where most things go anyway. We just have quite a few versatile pieces like IKEA shelves and Besta units, in different colors that need to go to different rooms.
FloHB123
27 Sep 2020 12:55
That's right, here the cabinets were also wrapped in foil, so marking them wouldn’t have helped. The main thing is to ensure that the furniture doesn’t end up on the wrong floor. Everything else can be adjusted quickly.
