ᐅ How easy is it to reassemble the IKEA Hemnes furniture after moving?
Created on: 10 Aug 2020 18:37
sarba
sarba
10 Aug 2020 18:37
Hello everyone, I am about to move and own several Hemnes furniture pieces from IKEA, including beds, shelves, and dressers. My question is how easy or difficult it is to reassemble these Hemnes items after the move into the new home. Specifically, I am interested in whether the Hemnes series is particularly prone to assembly errors, if the instructions remain clear after disassembling and packing the parts, and whether one or two helpers are usually enough or if professional advice or additional tools are needed. Does anyone in the community have extensive experience they could share? Are there any special tips to keep in mind to make the reassembly process as smooth as possible? Thank you in advance!
SUPE2
10 Aug 2020 18:44
Hemnes is generally quite easy to rebuild. It is important to keep all screws and parts stored separately and organized. With the instructions and one or two helpers, this usually works without any issues.
Domau0
10 Aug 2020 19:12
The Hemnes series is generally well designed for disassembly and reassembly. However, I strongly recommend storing the assembly instructions carefully after taking the furniture apart, and possibly saving a digital copy in case the paper version gets lost. During disassembly, you should number each screw and part or keep them in small labeled bags. I had good experiences with this method during my last move. Another important point concerns the back panels of some shelves: these are often attached only with small nails and can be easily damaged during disassembly and reassembly. When rebuilding, I also recommend having additional tools on hand besides the included Allen wrench, such as a small screwdriver or pliers, since some parts can be very tight. How many pieces of furniture are you planning to refurbish?
sarba
10 Aug 2020 19:36
Domau0 schrieb:
How many pieces of furniture do you plan to replace?
Thanks for the tips; backing up the instructions digitally is already very helpful. Mainly, there are two beds (180x200 cm (71x79 inches) and 140x200 cm (55x79 inches)), a display cabinet, and two tall shelving units. The shelving units do have back panels, which I intend to handle very carefully. What about potential material fatigue or fitting issues after disassembly? Are these common problems that might occur?
pilous
10 Aug 2020 20:05
sarba schrieb:
What about potential material fatigue or fitting inaccuracies after disassembly?
That’s a valid question. Hemnes is primarily made from solid pine wood, which is robust but can swell or shrink due to moisture exposure or improper storage. If you store the parts cool, dry, and flat after disassembly, fitting inaccuracies are significantly reduced. Material fatigue usually results from overtightening screws or repeated improper assembly. I also wonder whether everything really needs to be fully disassembled. Do you have an idea if, in your case, every piece of furniture will actually be completely taken apart or mostly partially disassembled?
sarba
11 Aug 2020 08:17
pilous schrieb:
Do you have an estimate whether, in your case, every piece of furniture will be completely disassembled or rather partially taken apart?
That’s a good question – as much as possible, I would prefer to only partially disassemble, for example, removing the headboard from the bed and the doors from the display cabinet, but keeping the side panels and shelves intact. Perhaps this could reduce the risk of fitting inaccuracies. In practice, is this a sensible approach for Hemnes, or could it be problematic, particularly for structural reasons?
