ᐅ Making the Most of IKEA Metod Storage in Tall Cabinets: Efficient Organization Tips
Created on: 14 Dec 2024 09:37
JilnauI am currently working on organizing and optimizing the use of IKEA Metod tall cabinets for storage in my kitchen. My focus is specifically on making practical use of the available depth and height, as the compartments are quite deep and can quickly become disorganized.
I am interested in recommendations for solutions to best divide the existing space and which IKEA or third-party organizers are most effective for keeping things tidy. Tips on adjusting shelves or using pull-outs or internal lifts would also be very helpful, as I am somewhat uncertain about how flexible the Metod tall cabinets are when it comes to interior customization to store both small and larger items in an orderly and easily accessible way.
Perhaps someone also has experience with maximizing storage space in tall cabinets with a depth of 60cm (24 inches) without items getting lost at the back or having to empty the entire cabinet frequently. Which systems or combinations can really make a difference here?
Hello Jilnau, your question is very well formulated, thank you for that!
Regarding the IKEA Metod tall cabinets: The shelves are usually height-adjustable, which allows you to adapt them to different needs. This way, you can quite easily store small items in more densely packed compartments and larger ones in other areas. It is important to create a basic structure that suits your habits, for example, placing frequently used items towards the front and less frequently used ones further back.
I recommend using the Metod interior drawers—they can be fully pulled out and provide better access to the rear storage space, which might otherwise be difficult to reach.
There are also storage boxes and baskets that stack well in such cabinets. As for the depth, I advise measuring different heights and installing corresponding intermediate shelves to better organize the space.
How about you—do you already use the interior drawers or are you using fixed shelves?
A very interesting and complex question, Jilnau.
Let’s start with the technical details: The IKEA Metod tall cabinet typically comes with a depth of 60 cm (24 inches) and adjustable heights for the shelves that can be installed. The metal side panels with holes allow flexible positioning of the shelves, usually spaced at 2.5 cm (1 inch), enabling fine adjustments. From my experience, it makes sense to plan the interior configuration in advance based on the items you want to store.
Basically, there are several types of inserts:
- Fixed wooden shelves
- Pull-out drawers (fully extendable)
- Internal lifts (mechanical and electric lifting devices, rather rare for home use but very space-saving)
The pull-out drawers are especially recommended because they allow full extension and contribute to better visibility, particularly with the 60 cm (24 inches) depth. A small tip: You can complement the pull-outs with plate or cutlery inserts to keep small parts from being stored loose.
We often talk about maximizing the height usage of the tall cabinet: Usually, you can install multiple shelves or drawers to create several levels, making efficient use of the storage space. For this, measure your own grid dimensions (for example, the height of the tallest item plus some clearance).
To avoid clutter at the back of the cabinet, using transparent boxes can be very helpful so you can see what’s inside at a glance.
An aspect often overlooked is ergonomics when organizing: If you regularly need to access heavy appliances or pots, these should be placed at an easily reachable height. Lighter or less frequently used items can be stored in higher or lower areas.
What are your preferred items for the tall cabinet? That could make the advice even more specific.
Dilen schrieb:
What are your preferred items to store in the tall cabinet? That could help make the advice more specific.Thanks, Dilen, that’s a good question. Mainly, I want to store pantry containers, large pots and pans, as well as kitchen tools that are used less frequently. Also, the tall cabinet often holds supplies in jars or packages that should have some protection to prevent them from tipping over or breaking.
So far, I’ve mainly had fixed shelves, but accessing the back of the cabinet is really difficult, especially when large pans or pots are stored further back.
The idea of creating different levels for various items seems sensible, perhaps with boxes or divider systems.
What about installing pull-out shelves when considering the heavy weight of pots? Are there any limitations with Metod? And are internal lift systems more than just a nice gadget, or do they actually make sense for such tall cabinets?
Regarding internal drawers and heavy loads with Metod: In general, IKEA’s internal drawers are designed for average kitchen use, so they can handle heavier pots and pans quite well. However, it’s important to observe the maximum load capacity specified by IKEA for the drawers—usually between 15 and 20 kg (33 and 44 lbs) per drawer.
A tip: For particularly heavy items, it makes sense to use wider and more robust drawers to better distribute the weight. Additionally, the aluminum or metal runners of the drawers provide good stability.
Internal lifts are, in my view, more of a comfort feature, useful when dealing with tall cupboards with limited access, or for very small kitchens. They help bring items to an optimal working height but are more expensive and technically more complex to install.
Personally, I prefer well-planned combinations of drawers and adjustable shelves, especially when heavy appliances or equipment need to be stored.
