ᐅ LED ceiling light connected but not working
Created on: 16 Mar 2023 14:26
0
0815Hesse
I installed an LED ceiling light. Previously, there was a halogen lamp that could be dimmed using the switch. Unfortunately, the LED light does not work. Could the problem be the dimmer switch? When I connect the LED ceiling light directly to a regular power cable, it works perfectly!
Thanks for your help
sysrun80
16 Mar 2023 17:12
0815Hesse schrieb:
Yes, 230 volts.
The LED lamp is already dimmable via remote control...
Yes, then just the switch insert and that’s it.
16 Mar 2023 23:29
If it’s that simple, then please share your experience. We had to switch back to halogen because nothing worked with LED…
sysrun80
16 Mar 2023 23:51
A few more details:
The packaging usually indicates whether an LED bulb is dimmable.
If it is NOT dimmable and connected to a dimmer, it can damage the LED bulb. So, it’s best to test the bulb without a dimmer first!
However, even if an LED is labeled as dimmable, that does not mean that every dimmer will work!
There are different types:
  • Universal dimmers for resistive loads with 230 V – incandescent bulbs, (line voltage) halogen
  • Dimmers for capacitive loads – for bulbs operating at 12 V, for example, with an electronic transformer
  • Dimmers for inductive loads – also with a transformer but a “classic” one (e.g. toroidal core)
The latter two types can work with dimmable LEDs – but not necessarily. It depends again on the type of LED.
