ᐅ LED ceiling light connected but not working
Created on: 16 Mar 2023 14:26
0
0815Hesse
0
0815Hesse
16 Mar 2023 14:26
I installed an LED ceiling light. Previously, there was a halogen lamp that could be dimmed using the switch. Unfortunately, the LED light does not work. Could the problem be the dimmer switch? When I connect the LED ceiling light directly to a regular power cable, it works perfectly!
Thanks for your help
sysrun80
16 Mar 2023 14:35
Yes, it is the dimmer. Leading edge or trailing edge phase control. There are many reasons why it might not work. LEDs in particular can sometimes be tricky.
0
0815Hesse
16 Mar 2023 15:29
Thank you for your reply. So, does that mean replacing the dimmer switch with a standard push-button switch?
sysrun80
16 Mar 2023 15:32
Either that or, if you want to dim, look for a suitable dimmer.
sysrun80
16 Mar 2023 16:12
0815Hesse schrieb:
I have installed an LED ceiling lamp. Previously, there was a halogen lamp connected, ...
Just to be sure: Was that a 230-volt halogen lamp? There isn’t a transformer in between, is there?
0
0815Hesse
16 Mar 2023 17:02
sysrun80 schrieb:
I just want to be sure: That was a 230-volt halogen lamp? There isn’t a transformer in between, right?
Yes, 230 volts.
The LED lamp itself is already dimmable via remote control...
