ᐅ Layout Design of the Master Bathroom
Created on: 18 Apr 2023 21:41
idasb79
First of all, thank you for your contributions in the previous floor plan discussions.
It has been a while, but now the construction site has progressed to the point where interior work and installations can begin.
We are uncertain about the design of the master bathroom. We have two layout options, but we would also like to hear your ideas.
The room measures approximately 315cm x 491cm (124 inches x 193 inches).
Please feel free to suggest completely different ideas as well.
Here are the examples for the placement of the fixtures.
K a t j a20 Apr 2023 13:18
hanghaus2023 schrieb:
By having the two balcony doors leading to nowhere, a lot of planning flexibility was lost and unnecessary costs were caused. Now you’ll have to install unattractive fall protection measures as well.
Furthermore, the lower glass panels will most likely soon be covered, taped over, or darkened in some other way.
hanghaus2023
20 Apr 2023 14:21
A solution with T
Floor plan of a bathroom with bathtub, door, and furniture
Or better like this?
Floor plan of a bathroom: bathtub on the left, double sinks on the right, red cabinets, doors, dimensions
Modern bathroom with stone wall shower, freestanding bathtub, double vanity, and mountain view.
Yosan
20 Apr 2023 16:39
A solution with a T
Is that still possible regarding the connections?
hanghaus2023
20 Apr 2023 17:32
Yosan schrieb:
Is that still possible in terms of the connections?
According to the original poster, the installer has not started yet. Otherwise, the floor plans are missing to be able to assess that.
K a t j a20 Apr 2023 18:59
Another option:
Floor plan of a bathroom with bathtub/shower, toilet, double sink, and doors.
I think the open space in front of the windows always makes the arrangement of the sanitary fixtures in the room look unbalanced.
idasb79
20 Apr 2023 20:33
Thank you very much for the many contributions. Below, I have tried to answer your questions.
A quick note:
To avoid distracting from the main question (the master bathroom), I did not upload the complete floor plan. Nevertheless, questions were asked about adjacent rooms or about the floor plans previously discussed here in the forum. In the end, a different floor plan was chosen than the one originally discussed.
K a t j a schrieb:
So, a French balcony? Or maybe a real balcony?
French balcony.
kbt09 schrieb:
How is the bathroom entrance door supposed to be there?
That is not yet fixed. A sliding door might also be an option.
kbt09 schrieb:
And if the 7x4 m (23x13 ft) room is the master bedroom... how is it actually going to be furnished?
The room will have a room divider to separate the dressing area and sleeping area.
Yosan schrieb:
Very quickly put together. But how about this:
The washbasin area is not appealing because it is too small, and the toilet position is not easily possible due to the drain.
I don’t understand the window situation. Is there a door behind the bathtub? Where does it lead?
Those are floor-to-ceiling windows with a French balcony. There is no exit there.
I assume the shell construction is already in place and no changes are planned for windows and doors.
Yes, the façade is finished and the windows are installed.
It seems none of the original floor plan drafts remain. Therefore, it would make sense to show the final floor plans here. Why is the children’s bathroom suddenly located in a completely different place?
It did become a different floor plan. We even made slight changes to the non-load-bearing walls during construction.
Yosan schrieb:
Why only start thinking about the bathroom layout once the shell construction is completed?
We slightly reduced the bathroom size compared to the original plan to enlarge the utility room. Therefore, the original bathroom layout no longer fits. See picture.
Architectural floor plan of a house with corridor and bathroom
Yosan schrieb:
Because some connections are fixed or similar.
Nothing is completely fixed yet. Only for the toilet, there are not many options due to the pipe diameter.
Now you still have to install those ugly fall protection barriers.
They cause costs, but we don’t find them ugly; on the contrary, they can even decorate the building. We find the divided version with a fixed bottom part unattractive and hard to maintain.
