ᐅ Common Issue: Kallax Doors No Longer Fit After Moving – What Can Be Done?
Created on: 18 Jan 2023 08:37
LaurusHello everyone,
I am currently facing the following issue: I took my Kallax shelves complete with the doors with me during a move and reassembled them. Unfortunately, the doors no longer fit properly after reassembly. They do not close flush and are difficult to open and close, as if the unit is slightly warped. I have compared the measurements several times – they are almost exactly the same as before at the previous location.
I am aware that Kallax shelves often have door problems if they are not aligned precisely, but in my case, this does not seem to be solely due to a misalignment. I wonder if slight warping or tension in the material could have occurred during transport or for other reasons.
Practically speaking: Has anyone experienced door issues with Kallax after a move? What solutions have worked for you? Is it usually enough to readjust the hinges, or is a complete replacement of the doors recommended?
Since I want to avoid buying a new set unnecessarily, I would greatly appreciate detailed advice, tips, and tricks.
Thanks in advance!
Thanks in advance!
nonpra schrieb:
First, check if the shelf is standing on a level surface.This is definitely the first step. Even a slightly tilted Kallax can already cause door problems.
Additionally, I recommend carefully checking that all screws and fittings on the shelf are securely tightened. Especially after moving, tensions in the wood and screws can easily loosen.
As a further measure, the hinges on the doors are adjustable, sometimes even on three axes. With a bit of patience, misalignments can be corrected this way.
If the doors still do not close properly, a slight deformation of the cabinet might be present. The problem is often that the shelf wood or the back panel is slightly warped. In such cases, a more extensive adjustment or replacing the doors is often necessary.
Regarding the specific problem analysis: Kallax shelves and their doors are essentially flat constructions made of particleboard with a melamine coating. Transport and moves can cause stress, which may result in slight warping.
1. Check flatness: Ideally place the shelf on a spirit level.
2. Inspect the entire carcass: Verify that all angles are correctly 90°, using a mitre square if necessary.
3. Check hinges for secure fit, adjust according to the manufacturer’s instructions.
4. Examine the doors for visible deformations.
If the carcass is warped, individual doors are difficult to adjust since they are generally not flexible. Replacement or custom modifications are often the solution here.
An alternative: remove the doors, continue using the shelf compartments, or order replacement parts tailored to the new dimensions.
Transport damage or stress effects often play a role, but precise measurement of angles and flatness usually proves to be the most helpful way to identify the source of the problem.
sarGabriel18 Jan 2023 15:37Readjust door hinges, reinforce the shelf from below if it wobbles.
Sometimes screws are simply loose after transport.
blapau schrieb:
As an additional feature, the door hinges are adjustable, in some cases even on three axes.Thanks for the tip, I wasn’t fully aware of that. So far, I’ve only tried to adjust the hinges superficially with one screw, but I didn’t know such a more complex adjustment was possible.
Fitigu schrieb:
Check if all angles are exactly 90°, possibly using a bevel gauge.I will check that tomorrow. I already have a spirit level, but I don’t have a suitable bevel gauge. I should be able to get one quickly at the hardware store.
Until now, I thought the material was stable, but the idea that stresses from transport could be strong enough to cause distortion sounds plausible.
Is there a recommended procedure for measuring this? For example, first the spirit level to check the floor’s flatness, then angle check on the shelving, and finally door adjustment?
