ᐅ KALLAX doors no longer fit properly after renovation – should they be adjusted?
Created on: 21 Oct 2022 08:43
KUFOPEO
Hello everyone, after a renovation I noticed that the doors on my KALLAX shelving unit no longer fit properly. The hinges now seem a bit strained, and the doors are hard to close or hang crookedly. My question is: Is there a way to adjust the KALLAX doors so they close cleanly and flush again? I suspect that the renovation – maybe a new floor or changes in the room – caused the frame to warp slightly. Has anyone had experience with readjusting KALLAX doors? Which screws on the hinges exactly need to be adjusted, and are there any tips for realigning the doors correctly? Thanks in advance for your input!
It’s amazing that KALLAX doors can still be adjusted! 🙂 I recently had a similar issue and managed to fix it with some fine-tuning of the hinges. Definitely give it a try—opening and adjusting them is fun, and when it fits perfectly, it’s a really great feeling of achievement! Good luck, you can do it!
I would like to add that when adjusting KALLAX doors, it is important to follow a systematic approach. I made a small checklist:
1. Remove the doors: Close them and lift slightly; usually, you can then lift them off from the top.
2. Check the hinges: It’s better to loosen all screws slightly first to allow some play.
3. Adjustment: Usually, there is one screw for lateral adjustment and one for height, sometimes also one for depth.
4. Adjust: Start with the lateral position, then the height, and finally the depth to ensure the door is flush.
5. Interim steps: Rehang and check repeatedly.
6. Tighten: Finally, carefully tighten the screws.
It is also important to make sure the hinges are not damaged; bent or loose parts will otherwise cost you time.
Can you check if the screws are still properly seated or if the cabinet frame has any warping?
Gafiel schrieb:
Could you please describe how much the doors are misaligned and whether the cabinet frame is stable? Are there any floor level variations, for example due to new flooring?Thank you for the detailed response! Yes, the floor was newly installed – laminate about 8 mm (0.3 inches) higher than before, which slightly raised the cabinet frame and caused it to tilt a bit. The doors are indeed somewhat misaligned; especially at the bottom, I can feel them pressing down slightly on the corner of the frame. This also causes a slight rubbing sound when I close them. The frame itself feels stable, just no longer perfectly vertical because of the floor.
Perhaps the height adjustment on the hinges is particularly relevant in this case?
Hello!
This fits perfectly with my experience: If the base has been raised, the cabinet tends to tilt slightly. To compensate for this, a combination of adjusting the hinge height and possibly adding small shims under the furniture legs usually helps.
The height adjustment is often possible via the screws directly on the hinge bracket. If your cabinet is slightly tilted, it’s true that the doors will then scrape at the bottom.
My tip: Adjust the furniture legs a bit to achieve as level a position as possible, then use the hinges for fine-tuning. This is usually the best approach 🙂
KUFOPEO schrieb:
Maybe the height adjustment on the hinges is especially relevant then?Exactly, the hinge height adjustment is the most important screw when there are changes in floor level. If the cabinet itself is stable, you can fix the problem with that.
I would like to add one critical point: especially with KALLAX units, adjusting the doors only helps as long as the main frame itself is not under stress. If the floor is uneven, this pressure can affect the frame and, in the worst case, cause cracks or deformations, even if these are not immediately visible.
What do you do to ensure a lasting solution? What measures do you use to stabilize and align the frame as straight as possible on uneven ground?
Constant readjustment alone is not a sustainable solution.
