ᐅ KALLAX Shelf Modified for Stereo System – Is It Strong Enough?
Created on: 3 Aug 2017 14:37
KOELENIHello everyone, I am currently planning to place my stereo system in an IKEA KALLAX shelving unit and am unsure if the shelf can withstand the weight and vibrations from the system over time. Specifically, I am talking about a combination of a receiver, turntable, and two compact speakers, which together are quite heavy and produce vibrations during playback.
Does anyone have experience with modified KALLAX units for safely and securely housing a stereo system? Should I consider reinforcing the material, or is the standard construction sufficient? I am concerned that the thin panels might bend under the weight or that the vibrations could damage the shelves in the long run.
I would appreciate any insights, especially practical tips on reinforcement or additional measures.
Hi KOELENI,
I have used a KALLAX for my stereo system myself and can say that the shelf is sufficient for normal use without major modifications, as long as the weight per compartment is not too high (max. about 10-12 kg (22-26 lbs) per unit). It is important to keep the back panel fixed, as this provides additional stability.
That’s true, since vibrations are particularly critical with turntables. I used rubber mats under the equipment, which help to dampen vibrations and protect the wood. For heavy receivers, you can alternatively screw metal brackets behind the shelves, which significantly increases load capacity.
A general weakness of the KALLAX is its fairly thin wood board, which can warp over time under too much weight, especially if the shelf is open and no additional braces are installed.
If you want to modify it more heavily, I would opt for a thicker board as a base and secure it to the back panel. But for moderate stereo systems, the KALLAX is solid enough.
nixon0 schrieb:
Vibrations can be transmitted less this way.
Oh, that sounds exciting! 🙂 I also set up my KALLAX with a turntable and a small stereo system and simply screwed in an extra shelf board, which significantly reinforced the entire space! Now it holds really firmly, and the vibrations are barely noticeable!
In my opinion, it’s definitely worth reinforcing the shelf in critical areas; it worked great for me. It also looks fantastic if you choose the wood carefully! A really cool DIY opportunity! Good luck, it’s sure to turn out great! :-)
KOELENI schrieb:
Do you need to reinforce the material, or is the standard construction sufficient?
The following facts can be noted regarding the durability of a modified KALLAX shelf unit for a stereo system:
1. KALLAX shelves are made of particleboard with a thin melamine coating, which limits the load capacity to approximately 13-15 kg (29-33 lbs) per compartment.
2. When used in a typical stereo setup with heavier components—especially turntables and receivers—it is advisable to reinforce the shelves with high-quality MDF boards or laminated beams.
3. The back panel plays a key role in the lateral stability of the shelf unit and should always remain securely attached.
4. Vibrations from speakers and turntables can be significantly reduced by using sound-dampening pads or rubber mats, which also help protect both the shelf and the equipment.
Conclusion: KALLAX can be used for stereo systems, but the load should be regularly monitored, and technical improvements made as necessary. Rear bracing, reinforced shelves, and vibration-dampening supports are strongly recommended.
