ᐅ KALLAX is chipping off at the exterior edge – what could be the cause?
Created on: 17 Jul 2017 08:27
learfraHello everyone,
I have the following issue with my KALLAX shelf from IKEA: the material is chipping off repeatedly along the outer edge. This is especially frustrating since the shelf is only a few months old and I have been very careful with it.
My question is, what could be causing this chipping? Could it be due to manufacturing quality, moisture, transport, or perhaps the assembly? Are there any known weak points or tips on how to prevent this?
I have mainly used the shelf for books and decorations, with a normal to light load. A few details: the shelf is located in a fairly dry room, and I assembled it according to the instructions without any modifications.
I would really appreciate your opinions and experiences!
learfra schrieb:
The material keeps chipping off at the outer edge. That really sounds frustrating! I had a similar issue some time ago with another IKEA piece of furniture, so I can fully understand how annoying that is.
From my experience, the chipping at the outer edges can actually be due to the surface layer; the particle boards used in KALLAX are only veneered or laminated, and the edges are often the most vulnerable part.
Unfortunately, this can also happen if the furniture is impacted by bumps, during transport, or through improper cleaning.
Have you moved or rearranged the shelf since assembling it? Sometimes the edges are especially stressed during such handling and can chip more easily.
I hope you find a good solution – one thing I can say is that this problem doesn’t seem to be uncommon, even though IKEA doesn’t always communicate much about it.
Lisele schrieb:
The issue doesn’t seem uncommon, even if IKEA doesn’t always communicate much about it. You could say that!
But I wonder if KALLAX is just accepting this problem? Maybe the material isn’t actually that vulnerable, but the ways people use it often exceed the product’s specifications. IKEA sells products in large volume, which also means compromises in durability.
I think discussions about these "defects" are often too focused on the manufacturer, whereas users should take a look at their own usage habits: Are the edges constantly being bumped? Is the shelf bending due to overloading? Could it be placed too close to a heat source?
Sometimes I feel too much is expected from warranty claims without applying common sense.
Don’t get me wrong, I’m not trying to minimize your concerns, but not everything can be blamed on the “product quality.”
LIELCHEN schrieb:
Sometimes I think too much is expected from warranty claims without applying common sense.I understand your point, but I don’t think that’s the main issue in my case.
The shelf is fixed in one place, it’s not moved or heavily loaded. The edges have not been bumped or scratched at all.
However, I’ve read that the KALLAX edges are covered with a thin edge banding film, which can be quite delicate. If moisture or humidity affects it, that could cause chipping.
Does anyone know if these films are really that sensitive to humidity, or if temperature fluctuations in normal indoor air make things worse?
For me, I see mainly two possible causes: weak edge sealing or production defects along the outer edge.
I’m also open to other opinions!
edisondan18 Jul 2017 12:34learfra schrieb:
However, I have read that the KALLAX edges are covered with a thin edging foil that can be relatively delicate.That is correct. KALLAX units are made from particleboard, with the edges covered by a thin edging foil. This foil protects against moisture and mechanical wear.
It is important to know that prolonged exposure to moisture or mechanical stress, such as impact to the edges, can cause the foil to swell, peel, or chip.
Unlike solid wood or solid materials, the surface of particleboard with foil edging is more sensitive. Temperature fluctuations can also affect the bonding of the foil, but these are rarely the primary cause.
If the shelving unit is frequently exposed to high humidity or direct water contact, this could explain the damage. Likewise, transport or installation involving edge bumps or minor impacts can cause damage.
In summary:
- Chips on KALLAX outer edges are usually due to mechanical stress or moisture.
- Manufacturing defects are rather uncommon.
- To prevent damage, edges should be protected from impacts and sources of moisture avoided.
I hope this assessment is helpful.
