ᐅ KALLAX Molded After Water Damage – Should I Save It or Dispose of It?
Created on: 15 Oct 2022 18:37
Pi-ge
Pi-ge
15 Oct 2022 18:37
I have a KALLAX shelf unit from IKEA that unfortunately developed significant mold damage due to water exposure in my apartment. It is the standard shelf made of wood fiberboard with a melamine coating. The mold is mainly visible on the lower shelves that were in direct contact with the water.
My question is whether it even makes sense to try to save a piece of furniture like this after such damage, or if it’s better to dispose of it completely. I have heard of different methods, such as thorough drying, wiping with alcohol-based cleaners, or using mold removers. On the other hand, wood fiberboard seems to be vulnerable to prolonged moisture and could suffer damage later or cause further mold growth.
How do you usually handle cases like this? What are the experiences with KALLAX or similar furniture after water damage or mold? Are there practical ways to remove mold and restore the furniture’s condition so it can still be used safely?
Thanks for your input!
kulau
15 Oct 2022 19:04
Hello Pi-ge,
First of all, regarding your KALLAX shelf: The material used is indeed particleboard or fiberboard with a melamine coating. The problem with water damage and mold is that the wood-core panels swell after prolonged moisture exposure, lose their structural integrity, and provide an ideal breeding ground for fungi. In general, surface mold can be removed, but for furniture panels that hardly breathe and whose moisture content is often difficult to control after water damage, the risk of mold regrowth is high.
I would recommend the following procedure:
1. Remove loose mold spots with a microfiber cloth and an alcohol-based cleaner (at least 70% isopropanol) – this kills the mold.
2. Then dry intensively, ideally using a dehumidifier and good air circulation to avoid any remaining moisture.
3. Check the strength and stability of the panels: If the panels are soft or swollen, their load-bearing capacity is significantly reduced.
4. If the panels are still stable, you can continue to use the shelf, but the affected areas should remain permanently dry because mold spores may still survive latently.
5. Alternatively, if you want to be on the safe side and the furniture is not particularly valuable, disposal is often the best option – especially with severe water damage.
One question for you: How long was the shelf in contact with water? Did it have time to dry, or was it wet for a long period? This makes a big difference in how deeply the mold can penetrate.
In general: With furniture made from wood fiberboard, such as IKEA KALLAX, it’s a tricky situation – with some luck, you can save it; with bad luck, it’s a case for disposal.
PeoDaniel
15 Oct 2022 19:59
kulau schrieb:
One question for you: How long was the shelf exposed to water? Did it have time to dry, or was it wet for an extended period?
This is indeed a very important point. Mold growth strongly depends on how long the moisture was present. With short exposure and quick drying, mold can often be removed, but the longer the moisture remains, the deeper the spores can penetrate.
Pi-ge schrieb:
The mold is mainly visible on the lower shelves that were in direct contact with the remaining water.
If only the lower shelves are affected, and the upper shelves are still stable and dry, it might be worth considering a selective replacement of the damaged shelf boards. This could be a more cost-effective alternative to replacing the entire unit.
It is also important to remove the mold using appropriate agents (e.g., alcohol-based cleaners or special mold removers) and afterwards ensure a completely dry environment to prevent recurrence.
If possible, I would recommend checking the moisture content of the material with a wood moisture meter before making a final decision. This provides more certainty about the condition of the boards.
In general, repairs can be worthwhile if the damage is limited to small, clearly defined areas. With prolonged exposure to moisture and extensive mold growth, disposal is usually the simpler and safer option.
GU-LAU60
16 Oct 2022 08:22
Discard the shelf if it is severely moldy. Fiberboard absorbs water, swells, and will mold again. If there is mold in the furniture, I would not hesitate.
Lotizar
17 Oct 2022 14:11
As an addition: KALLAX is made of wood fiberboard with a melamine foil coating, which is not water-resistant. Therefore, mold growth is not merely a cosmetic issue but affects the load-bearing capacity and indoor air quality due to the release of spores.
A complete restoration is difficult because moisture penetrates into the material. Cleaning with alcohol-based products only helps superficially. Without thorough drying and stability testing, there is an increased risk that the furniture parts will suffer further damage.
For safety and hygiene reasons, it is advisable to dispose of furniture with significant mold infestation. Light mold growth that is detected early may be salvageable through intensive cleaning and drying; however, with KALLAX, this risk is usually too high.
Another tip: When purchasing chipboard-based furniture next time, look for water-resistant versions or, in such areas, consider using solid wood or metal shelving instead.
