ᐅ KALLAX open back – back panel strip installed – does this help in the long term?
Created on: 28 Sep 2023 19:03
TORUNSE47T
TORUNSE4728 Sep 2023 19:03I recently bought the IKEA KALLAX shelving unit, but I quickly noticed that the back panel is not firmly attached – it’s basically a loose backing that is just slotted in and doesn’t provide a stable connection. Therefore, I have been considering screwing on a thicker back batten or some kind of backing strip to stabilize the carcass in the long term and prevent warping.
My main question is: Does adding a back batten to the rear of the KALLAX really help prevent warping over time and improve stability? Or is this more of a short-term fix that offers little benefit and might even cause other issues, such as the side panels deforming?
I’m also interested in which materials work best for this purpose and whether there are practical mounting systems that make a real difference. Looking forward to your experiences and opinions!
Hi, the issue with the loose back panel on KALLAX units is quite well known. The original back panel is usually made of relatively thin hardboard or particleboard material, which is simply slotted in to hold the shelving unit together. While this is simple and cost-effective, it often isn’t sufficient to prevent warping over larger widths — especially if the shelf is frequently moved or heavily loaded.
A back cleat or strip mounted on the rear can definitely help because it essentially connects the two side panels and makes twisting of the structure more difficult. However, there are important points to consider: the cleat should preferably be made from solid wood and not too thin to provide adequate stability; a simple thin wooden strip often isn’t enough. The fastening method also plays a key role — ideally, multiple screws with wall plugs or pan-head screws should be used to ensure a secure hold.
A common mistake is installing only one strip and mounting it incorrectly, for example, without applying pressure to the unit, because that doesn’t increase tension. It is important that the back cleat effectively pulls the unit together to enhance stability.
In my experience, it is definitely better than relying on the original back panel alone — especially for shelving units with more than 4 or 5 compartments. Whether it’s a permanent solution, of course, depends on how the cleat is installed and how the shelf is loaded. For long-term stability, additional measures can be considered, such as completely replacing the back panel with a more robust wooden board or installing diagonal braces inside.
Which materials and methods you choose depends on how much effort you want to invest. Solid wood strips are sturdy, easy to screw in, and can also be painted or oiled. Metal brackets are another option.
I hope this helps clarify things a bit. How wide and tall is your KALLAX? How heavy will the back panel load be?
TORUNSE47 schrieb:
Does a back cleat added to the rear of the KALLAX really help prevent warping in the long run and provide more stability?
PeoDaniel28 Sep 2023 21:48Great question, as many people underestimate the importance of the back panel in KALLAX shelves.
I would like to support Dilen and further explain why the back panel is so important: it primarily provides torsional stability, meaning it prevents the shelf from twisting lengthwise or the side panels from bowing outward.
As Dilen already mentioned, the loose back panel offers limited long-term stability because it lies flat and is fixed with small nails or pins. That’s why I recommend installing a sturdier back strip—ideally several strips attached both horizontally and vertically. This way, the frame is essentially “framed in” and forms a stable unit.
A strip about 18-20 mm (0.7-0.8 inches) thick, made of pine or beech, is usually ideal. Thinner material might warp over time, which would negate the benefit. Install the strip directly centered along the back edge of the cabinet with at least two to three screws per connection point.
I think attaching a back strip is a worthwhile investment in stability, especially if you move the shelf frequently or load it heavily (e.g., with plants or stacks of books).
If you want it particularly stable and protected, a full back panel made of 6-8 mm (0.25-0.3 inches) plywood or MDF is an option—although this requires more effort.
Are there any specific loads or uses for your shelf? Do you use it for heavy items? Maybe we can provide some tailored advice.
Dilen schrieb:
The strip should be made of solid wood and not too thin to provide sufficient stability
Yes, a rear wall strip definitely helps in the long term. Stability is significantly increased because it holds the cabinet together and minimizes twisting.
Simply screw it on, preferably with several screws along the height. Thin strips are of little use; use at least 15 mm (0.6 inches) thickness.
For KALLAX, the original backing is often not sufficient, especially if it is larger or frequently moved.
It is important to me to also consider the long-term technical effects of a back strip on the KALLAX.
Although the KALLAX carcass is held together by the loose back panel, an unsecured back panel does not generate significant tensile forces on the side panels. Without these tensile forces, the furniture may experience minor twisting or warping—usually noticeable only after months or years.
That is correct; the additional strip, when properly sized and installed with sufficient pressure, acts like a frame reinforcement. It is crucial that the strip is firmly screwed along the top and bottom edges of the shelving unit under high clamping pressure. Screws that are too loose have little effect.
Another important aspect is the cut edge of the side panels—the additional strip creates tensile forces that counteract the side panels being pushed apart under load.
From a material standpoint, strips made of solid pine wood are highly recommended; they are hard and easy to work with. It is important to monitor the wood moisture content carefully, as loosening of the screws can occur otherwise.
My recommendation for a long-lasting solution: a combination of a stronger back strip plus diagonal bracing (e.g., metal brackets or a cross brace) can provide even more effective stability if you plan to use your shelf intensively.
What is the intended use of your shelf? Storage for heavy items or more lightweight decorations and books?
ju_ren schrieb:
The stability is significantly increased because it holds the carcass together and minimizes twisting.
