I recently got an IKEA KALLAX shelf unit and have been using the matching fabric storage boxes as inserts. Unfortunately, I’m having the issue that the boxes fit too loosely in the shelf, causing them to often tip forward or to the side, which makes the whole setup feel somewhat unstable.
My question to you: Have you had similar experiences with the KALLAX and the fabric boxes? How did you solve or at least improve this problem? Are there any tips or small modifications that can prevent the boxes from being too wobbly?
I’d like to know if this is just a common issue with the fabric boxes in the KALLAX or if it’s because I’m doing something wrong when inserting them. Any advice or experiences are welcome, even if you use different insert options. Thanks in advance!
gikimu schrieb:
Have you had similar experiences with the KALLAX and the fabric boxes?Yes, I know that all too well! These fabric boxes often don’t fit very snugly—the combination of lightweight material and a simply designed shelving unit tends to cause a bit of wobble. ;-)
My trick: I’ve attached very thin foam strips or foam rubber to the inside edges of the shelves where the boxes make contact. This adds some friction and greatly stabilizes the boxes. It’s also almost invisible and requires minimal effort.
Additionally, filling the boxes as fully as possible helps— the fuller they are, the less play there is.
So, if you’re up for a DIY tip, try using small foam pads like that. 🙂
Interesting question! The fit of fabric storage boxes in KALLAX shelves is actually a common topic.
Basically, IKEA intentionally designed the KALLAX fabric boxes with some tolerance so that they can be easily removed. Unfortunately, this means they do not fit tightly and can wobble slightly.
Technically, the issue comes down to several factors:
1. Dimensions: The fabric boxes are about 1 to 2 cm (0.4 to 0.8 inches) smaller than the internal dimensions of the KALLAX compartments.
2. Material: Fabric is flexible and compressible, which also applies to the shelf base in some cases.
3. Lack of fasteners: There are no additional securing elements to hold the box firmly on the sides.
What can help:
- As LAYNE mentioned, narrow foam strips or hook-and-loop fasteners (Velcro) on the sides can help to stabilize the box somewhat.
- Alternatively, you can make a thin frame from wood or rigid plastic, which is glued or screwed inside to create a tighter fit for the box.
- It is also worthwhile to line the boxes with sturdy paper or thin cardboard to stiffen the sides and reduce flexibility.
A question: How exactly do you use your boxes – are they often empty, half full, or heavily loaded? That significantly affects stability.
What can help:
kibutar schrieb:
A quick question: How exactly do you use your boxes – are they often completely empty, half-filled, or heavily loaded?Thank you for the detailed explanation!
Regarding your question: The boxes are usually at most half-filled, as I store relatively light items like clothes and small accessories in them. Some are sometimes almost empty when I’m taking things out of the closet or rearranging.
That probably also explains why they fit loosely and wobble. I had hoped that the sturdy structure of the KALLAX would provide more stability, but obviously, the combination with the fabric boxes presents a challenge.
I will first try your advice with foam strips. If it helps, I’ll get back to you.
Regarding the topic "KALLAX insert with fabric boxes – too loose for you?" I would like to provide a short guide on how to improve the fit without damaging the material.
1. Gather materials:
- Thin foam or sponge strips, about 3-5 mm (0.1-0.2 inches) thick
- Double-sided tape or removable adhesive
2. Preparation:
- Clean the inside surfaces of the KALLAX compartment thoroughly to ensure the tape sticks well.
3. Attachment:
- Stick the foam strips to the side walls, back panel, and also beneath the shelf where the box makes contact.
- Place the strips so the box fits snugly but not too tight. The goal is gentle friction.
4. Finishing:
- Insert the fabric box and test the firmness. Add or adjust strips if needed.
Additionally, you can slightly stuff the corners of the fabric boxes to make them puffier and feel more secure.
Important: Avoid permanent modifications to the boxes in case you want to use them differently later. This method is reversible and preserves the material.
I have regularly done this for myself and some friends – it works very well and is pleasantly cost-effective. 🙂
2. Preparation:
3. Attachment:
4. Finishing:
