ᐅ KALLAX doors too heavy for children – how to make them easier to handle?
Created on: 22 Feb 2017 08:37
burzin-r42B
burzin-r4222 Feb 2017 08:37Hello everyone,
I have the following concern: We have the IKEA KALLAX shelving unit with doors, which we use in the children's room. However, the doors are quite heavy and feel stiff, which prevents our children (3 and 5 years old) from opening or closing them independently and safely. This is not only frustrating for the kids but also poses a safety risk, as they could sometimes pinch their fingers.
I have been considering whether the weight of the doors can be reduced or if the mechanism can be improved to make the doors easier and more child-friendly to operate. Are there any effective, proven methods for this? Maybe you already have your own solutions or recommendations that could help make KALLAX doors safer and easier for children to use? Thanks for your tips and experiences!
burzin-r42 schrieb:
Unfortunately, the doors are quite heavy and feel rather stiff, which prevents our children (3 and 5 years old) from opening or closing them independently and safely.Have you measured the weight or do you have a description of the hinges and magnets? Often the issue is not just the door’s weight but also the resistance from the hinges and dampers. It’s worth checking these components thoroughly. Additionally, it’s helpful to analyze how frequently and how forcefully the doors are opened and closed to identify any specific weak points in the system.
Have you considered installing alternative door handles or a supportive mechanism such as a soft-close with spring assistance? I am skeptical that a simple “ease of use” adjustment without some modification will be sufficient.
guillaume22 Feb 2017 10:41For KALLAX doors, I recommend replacing the standard hinges with lighter or soft-close versions. Additionally, using a handle that is easier to grip, such as an elongated handle or a pull strap, can help. Removing magnetic catches or using weaker magnets also reduces the force needed to open the doors noticeably.
In my experience, the problem can be effectively solved with hydraulic hinges or gas-assisted hinge mechanisms. These systems balance the weight of the door and significantly aid in opening and closing.
Additionally, it is advisable to regularly adjust the doors to eliminate unnecessary resistance caused by poorly aligned hinges.
Overall, the effort required is noticeably reduced, which significantly eases the strain for children.
Tause schrieb:
It is worth specifically checking these components.This is crucial. In my opinion, the first step is a thorough assessment to determine whether the doors are actually too heavy or if the design of the hinges and locks is causing the problem to worsen.
Additionally, I recommend installing a soft-close mechanism or even removing the doors altogether if their benefit does not outweigh the drawbacks. Safety is especially the top priority when children are involved.
For a more precise solution, I recommend the following approach:
1. Measure the weight of the doors.
2. Remove the hinges and magnets and check the force required to operate them.
3. Look for replacement components for hinges and handles, specifically those with lower friction or spring-assisted.
4. Alternatively, consider installing soft-close or self-closing mechanisms if they reduce the force needed to open the doors.
All measures should be planned based on technical expertise to effectively address the root causes of the problem.
