ᐅ KALLAX doors slam shut when there is a draft – how can this be prevented?
Created on: 28 Dec 2024 10:37
Jeremias42
Jeremias42
28 Dec 2024 10:37
I’ve noticed that the doors on my IKEA KALLAX shelving unit open with even the slightest draft. This is quite annoying, especially in rooms where there is frequent airflow or regular ventilation. The problem persists despite the magnetic catch, which is supposed to prevent the doors from opening so easily.
I’m interested in learning about methods or tricks to keep the doors securely closed without major modifications or added furniture constraints. Has anyone experienced similar issues? Specifically, which solutions work well in cases of unavoidable drafts? I want to avoid the doors constantly rattling or opening on their own without intervention.
Looking forward to your tips and suggestions!
lisku
28 Dec 2024 11:02
Hey Jeremias42,
try reinforcing or replacing the magnetic catches. There are stronger magnets that hold better. If that’s not enough, a simple rubber doorstop or a small strip of hook-and-loop fastener that secures the door when closed can help.
Filippo
28 Dec 2024 14:26
Hello Jeremias42,
I am familiar with this issue as I also use KALLAX doors and regularly struggle with them opening due to drafts. This is mainly caused by the lightweight hinges and the low mass of the doors combined with relatively weak magnets.
Here are some detailed steps I can recommend:
1. Magnet replacement: IKEA often uses weak magnets that can be swapped out. Use stronger neodymium magnets, but be careful with their placement to avoid repelling forces.
2. Door adjustment: Sometimes the hinges are slightly misaligned, causing the doors not to close flush. Precise alignment can improve the holding force.
3. Self-adhesive rubber buffers: You can attach these to the inside edges of the doors to improve sealing and reduce the chance of them opening easily.
4. Additional Velcro strips: Small strips applied inside provide a secure hold without affecting the appearance.
5. Alternatively, mechanical latches: For particularly strong drafts, you can install small snap locks that need to be opened manually.
One last tip: Check the strength and direction of the draft. If possible, adjust the airflow—for example, by closing other windows or doors—so that the KALLAX is less directly affected.
I’m curious, have you measured the exact gap between the door and the frame? This affects the effectiveness of the magnets and how the door contacts the frame.
Jensson
29 Dec 2024 09:15
Good morning,
to address the issue with KALLAX doors opening due to drafts in a more systematic way, the following approach is recommended:
1. Hinge inspection: Especially with KALLAX, the hinges are often installed so that the doors do not sit tightly. Check if the hinges are properly adjusted. Even a few millimeters (inches) more pressure can significantly improve the holding force.
2. Stronger magnets: As mentioned before, the existing magnetic catches can be easily replaced. There are aftermarket stronger magnets specifically designed for furniture that fit universally on IKEA KALLAX units.
3. Installation of door catch devices: These are available in various designs (depending on preference, mechanical or magnetic). They provide additional stability for the door, even under stronger air drafts.
4. Decoupling airflow: If the room experiences strong drafts from ventilation, placing an air deflector directly in front of the KALLAX might be helpful. This can be easily done using small room dividers or furniture.
Summary:
- Precisely adjust the hinges
- Use stronger magnets
- Consider additional door catches
- Optimize room layout and airflow management
This will significantly reduce the doors opening due to drafts.
Filippo schrieb:
Precise alignment can improve holding force.
This is crucial because even small gaps quickly reduce the effectiveness of magnets.
lisku schrieb:
simple door stopper or Velcro
Velcro can be a practical and inexpensive solution, although it may not be visually appealing to everyone.
KAULIS
30 Dec 2024 16:42
To complement the measures already mentioned, I would like to explain the physical background: KALLAX doors are lightweight and their magnetic catches are relatively weak, which can be problematic in case of drafts.
Airflows exert small forces on the doors that are enough to open them if the holding forces are insufficient. To calculate the required holding force, one can measure the draft in cubic meters per hour and derive the forces acting on the door surface from that. Although this is rarely done in practice, it provides a basis for selecting the strength of the magnets or mechanical fasteners.
Another technical measure would be installing sealing lips or brush seals on the inside of the cabinet, which not only seal the draft but also create additional friction against opening.
Additionally, the door hinges should be checked and, if necessary, replaced with models that have stronger closing springs, provided they are compatible.
The advantage of mechanical solutions is their independence from air pressure changes. If there are no visual or construction constraints, I recommend a combination of stronger magnets and a rubber seal on the inside of the door.
This creates a good compromise between functionality and a simple, practical effort.
Filippo
2 Jan 2025 08:11
KAULIS schrieb:
The combination of stronger magnets and a rubber seal on the inside of the door represents a good compromise.
Exactly. I wanted to add that retrofitting with neodymium magnets can be quite challenging because you need to pay close attention to the correct strength and spacing. Otherwise, they won’t work properly or might even stretch the material.
Is it possible for you to remove the doors and take precise measurements? That’s the only way to determine the best position for the magnets. Also, the surface of the cabinet is important—magnet strips usually hold better on painted surfaces than individual magnets.
How strong is your current draft, or do you feel the doors open every time there is ventilation, or only with fairly strong airflow?
If the draft is very strong, you could even consider fitting the doors with slim snap catches, depending on the design. These can be discreetly glued inside and require more force to open without affecting the appearance.
Looking forward to hearing what you decide!
