ᐅ KALLAX doors shift out of alignment after installation – any experiences?
Created on: 31 Jul 2024 14:22
Keline
Keline
31 Jul 2024 14:22
I recently installed the doors on my KALLAX shelving unit, but I noticed that after installation the doors tend to shift out of alignment. Specifically, they no longer sit perfectly flush and parallel to each other, but are slightly offset, causing small gaps to appear when closing that weren’t there before.
I have double-checked all adjustments and screws multiple times, and the sliding tracks seem to be properly secured. Have you had similar experiences with KALLAX doors shifting after installation? How do you ensure the doors stay aligned over time? Are there any special tips or technical details I should be aware of to prevent or fix this issue?
Looking forward to your advice and suggestions!
PeoDaniel
31 Jul 2024 14:47
Hello Keline,
your description suggests that during the installation of the doors, the running tracks or guide rails may not have been perfectly aligned. KALLAX doors slide on rails that are mounted on the inside of the shelving unit. Even small deviations when fastening can cause the doors to jam or not sit parallel.
You should first check whether the running tracks are mounted exactly level and at the same distance from each other. This ensures that the doors move properly and without misalignment. It can also help to carefully remove the doors, inspect the rails, and adjust them if necessary using a spirit level.
Another point is that the doors can sometimes shift slightly after installation due to material flexibility, so it is advisable to retighten the screws after a few days.
Have you already tried rehanging and realigning the doors? If so, what exact procedure did you follow? I would be happy to assist you further.
benon
31 Jul 2024 15:12
PeoDaniel schrieb:
You should first check whether the running rails are installed perfectly level and at the same distance from each other.
I agree with that. Additionally, cleaning the guide rails to remove any manufacturing dust can help – this ensures smoother movement and prevents jamming.
Also, make sure the screws are fully tightened but not overly tight, as the wood can warp otherwise.
How are your fixing points distributed? Did you use all the recommended screws or just the minimum number?
Marcellela
31 Jul 2024 16:05
Are the doors evenly loaded? Sometimes doors warp if, for example, a shelf section is too heavy or loaded unevenly.
Also, check if the doors are properly hung: the top track usually guides the door, and if the door doesn’t engage correctly there, everything shifts.
Domau0
1 Aug 2024 08:37
Good morning,
to specifically address the issue of KALLAX doors sliding out of alignment, it is important to take a closer look at the entire track system, door mechanics, and surrounding materials.
1. Check the track installation:
Use a precise level to ensure that both the upper and lower tracks are installed exactly parallel and perfectly horizontal. Even very small deviations of a few millimeters can cause doors to become misaligned.
2. Door hanging:
KALLAX doors are usually hung with hanging hinges on the upper track and run on guide rollers at the bottom. It can happen that the hinge points are not evenly positioned or the rollers do not run synchronously. Check if all rollers move smoothly and if the door is securely attached at the hinges, but not too tight.
3. Material warping and stress:
Wood-based materials can warp slightly depending on exposure to moisture and load. Check if components other than the door itself, such as shelves or back panels, are putting pressure on the doors.
4. Adjustment and retightening:
Sometimes it helps to slightly loosen all screws, align the doors, and then gradually retighten the screws, checking the door alignment repeatedly. Alternatively, IKEA often provides small adjustment screws or clips on the doors to optimize their position.
5. Finally, I recommend reviewing the assembly instructions in detail, if possible, to ensure that all steps were followed precisely.
How clear is it whether all these points have already been checked on your end? Perhaps you could describe your approach, then I can assist you more effectively.
Keline
1 Aug 2024 10:29
Domau0 schrieb:
Check whether all the rollers move smoothly and if the door is firmly attached at the hinges, but not too tight.
Thank you for the detailed overview. I checked the tracks with a spirit level; they are horizontal and parallel. I used the recommended number of screws for the mounting and didn’t miss any.
The doors hang on the upper tracks and roll at the bottom on wheels that run in plastic guides. Today, I will test again whether these wheels roll freely and loosen the hinges slightly if they are too tight.
The shelving unit stands freely and isn’t overloaded, and the back panel fits without any tension.
If the issue persists, could it be due to factory inaccuracies or warped materials? Is something like this known with KALLAX?
Here is the question again:
Are there known experiences where KALLAX doors come out of alignment despite correct assembly and adjustments, possibly due to manufacturing tolerances or material behavior? And are there any tips or tricks that help maintain the alignment over the long term?
