ᐅ KALLAX doors no longer fit properly after replacing the baseboards – what can be done?
Created on: 16 May 2022 14:03
rupuken
I recently upgraded my IKEA KALLAX shelves with new doors and, at the same time, replaced the baseboards in the room to create a consistent look. After changing the baseboards, however, the KALLAX doors no longer fit properly within the frames—they start rubbing against the edges and some are difficult to close. I made sure not to adjust the hinges, and the shelf frames themselves appear unchanged.
Does anyone have an idea what might be causing this issue with the doors, considering that only the baseboards were replaced? Is there any connection between the baseboards and the door installation on KALLAX units that I might be missing? Or what else could explain why the doors suddenly don’t close correctly?
I would appreciate any tips, advice, or pointers to common causes!
JONSON
16 May 2022 14:44
It is also possible that replacing the baseboards slightly altered the structural load. If the baseboards are thicker or have a different edge profile, the shelf might tilt forward a little, which could affect doors at the edges. Check whether the shelf is securely fixed to the wall and does not wobble. If necessary, secure it further.
rupuken
16 May 2022 14:47
glapu schrieb:
Door doesn’t fit? Try marking the edges with masking tape or a matchstick
Thanks for the tip, I’ll try that first thing tomorrow.
JONSON schrieb:
Tilt the shelf slightly forward
Tilting sounds like a very good idea. I had already checked the shelf but hadn’t really considered any tilting movement. Focusing strictly on the spirit level made me overlook this aspect unconsciously.
CARLA
16 May 2022 15:02
Additionally, it should be noted that KALLAX doors have relatively tight tolerances. If the floor or baseboards have even minimal height differences, this can trigger a chain reaction leading to such issues.
Suggested solutions:
- Check the floor level at the base of the unit by fine-tuning the adjustable feet or by placing felt pads underneath.
- Readjust the door hinges with minor micro-adjustments.
- Ensure that the back panel of the unit is aligned and fixed to the wall to prevent misalignment.
These are common causes of poor door fitment with KALLAX after floor work.
GiRoyce
16 May 2022 15:09
Hello rupuken,
It sounds like your previous checks have been thorough. The only additional recommendation I have is to completely remove the doors and remount them on a flat surface. This way, you might be able to determine whether the doors have slightly warped during the repositioning process.
Sometimes, the position of the screws in the hinges can shift a little after multiple adjustments.
When you take the doors off, you can also hold them up against the shelving unit to check if the dimensions are generally accurate.
KNUTGI
16 May 2022 15:17
I would add a casual tip: Sometimes it helps to lightly sand the doors – that means removing a very small amount of material at the points where they catch. But really minimal, otherwise it can become problematic. ;-)
Otherwise, to me it also sounds like a slight misalignment of the shelf or the base. Just a bit of sensitivity for millimeters, and the door will slide smoothly again like butter! 🙂
rupuken
17 May 2022 08:44
Good morning everyone,
after following your advice, especially marking the contact points with masking tape, I confirmed that the doors are rubbing at the lower right corner and the upper left edge.
In addition, I noticed that the shelf is slightly tilted backward due to a minimal height difference in the new baseboards, which was not the case before. This contradicts my previous level measurements, as I only checked the upper frame.
I am thinking of leveling the shelf, meaning lifting it slightly and compensating with felt pads. I will carefully adjust the doors again when I have the chance.
Does anyone have a tip on how many millimeters at most can be compensated in KALLAX shelves as a tolerance without compromising stability or door function?
