ᐅ KALLAX Doors Won't Open – Tips for Installation?
Created on: 24 May 2023 18:42
muna6
muna6
24 May 2023 18:42
I recently installed a KALLAX shelving unit from IKEA with the matching doors. However, I just can’t get the doors to open properly! The hinges seem to be installed correctly, but somehow the doors stick or are difficult to open. I made sure the screws are tight and the door frames are not warped, but that hasn’t improved anything.
Does anyone have experience with fitting the KALLAX doors? Are there any specific tips or tricks to ensure smooth opening and closing? Would it help to adjust the hinges, or could the issue be related to the door alignment?
I would appreciate any advice, as I really don’t know what else to try.
derrick34
24 May 2023 19:05
The doors can usually be fixed by adjusting the hinges. Check if the screws on the hinges are loose. If they are, tighten them, but not too much. If the doors fit too tightly against the cabinet, it often helps to loosen the hinges slightly and realign the door.
Siflo
25 May 2023 08:33
Regarding the issue of KALLAX doors that are difficult to use or do not close properly, the following points should be noted: The doors have so-called 3-way adjustable hinges, which allow you to adjust the alignment in height, depth, and sideways.
It is important to first check the sideways alignment, as the problem is often caused by a too tight stop if the door sits too deep in the frame. Adjustment is made by screws on the hinge body.
Additionally, ensure that the shelving unit is placed on a level surface, as an uneven base makes proper adjustment more difficult.
Another issue can be that the screws on the hinge and door are not tightened enough, which can cause jamming or binding.
My tip: Remove the doors, systematically adjust the hinges (with the door mounted), then carefully rehang the door and test its function. If problems persist, check whether the edges of the shelving unit or the door are uneven or damaged.
nedagla
25 May 2023 19:57
Wow, I know that all too well! 🙂 The KALLAX doors are really practical, but adjusting them can definitely be frustrating!
derrick34 schrieb:
Most of the time, you can fix the doors by adjusting the hinges.
That’s absolutely true—sometimes just a tiny turn of the wrong screw and the door won’t hang properly anymore. So definitely check every screw one by one!
Siflo schrieb:
The doors have 3-way adjustable hinges, allowing you to fine-tune the alignment in height, depth, and sideways.
Here’s how I did it: remove the door, loosen all the screws first, then align the door, tighten the hinges, and reinstall the door. Sometimes it also helps to slightly lift or lower the door before tightening the screws.
Don’t give up! Eventually it works, and then you’ll be even happier 🙂 Good luck to everyone working on this right now!!
