ᐅ Kallax can only be assembled with force after transportation – any tips?
Created on: 13 Oct 2021 17:38
TilegendHello everyone,
I recently purchased a Kallax shelving unit and must say the delivery went smoothly. However, I am now facing a significant problem during assembly: after transport, the individual parts hardly fit together anymore. Even after several attempts, the unit can only be assembled with considerable force. I understand that Kallax modules are generally manufactured with a precise fit, but here it seems like nothing fits together properly anymore.
Does anyone have an idea what might be causing this? For example, could the parts have swollen or warped due to moisture or distortion during transport and storage? Are there any tips on how to assemble the construction more easily without damaging the material?
I want to avoid causing any damage, but using excessive force is definitely not a solution.
I look forward to your experiences and advice, thanks!
Hello Tilegend,
first of all, this is a common issue when transporting Kallax or similar modules and moisture is involved. These furniture pieces, made from particle board or similar materials, are unfortunately very sensitive to moisture. Absorbent edges swell when exposed to moisture, which leads to slight warping. This then makes assembly much more difficult.
That is often exactly the case. I recommend the following approach:
1. Sort the parts and carefully inspect all edges. Pay special attention to moisture spots, swollen cutouts, or discolored areas.
2. Place the Kallax in a dry room and let the parts “breathe” for at least 24 hours. Often, the fit improves as the pieces return to room temperature and dry out slightly.
3. Try to gently slide the parts into place; never force them, as this risks cracks or chipping.
4. If you have professional tools, you could use very fine sandpaper to make slight edge adjustments, but this requires practice.
In general: if you feel the panels are heavily warped, the only solution may be a return or exchange, since the material can suffer permanent damage from swelling.
How exactly does the fit look? Are all joints affected, or only certain areas? What tools are you currently using for assembly?
Tilegend schrieb:
whether the parts might swell or warp due to moisture during transport and storage?
Hey Tilegend!
Wow, that sounds frustrating, but you’ll definitely manage it! 🙂
I had the same problem after my last IKEA delivery – sometimes patience and the right approach when assembling really help.
What worked great for me: Lightly dampen the parts with a wet cloth, then let them dry briefly before slowly fitting them together. The slight moisture often makes it easier to slide the edges without them getting stuck. Important: Use only a small amount of water, just dampen slightly and be careful.
Also: Sometimes it helps to gently rub the connecting points beforehand with wax or a piece of a candle stub (yeah, that sounds strange, I know). This adds a bit of lubrication so the joints slide together more easily.
Don’t worry, the problem usually gets solved quicker than you think! And once you have the shelf assembled, post some nice pictures of your work 😉 Good luck!
I can easily understand how frustrating it must be when a normally practical Kallax suddenly only goes together with force.
I had a similar experience once, and what really helped me was completely disassembling the entire piece of furniture first and checking each connection point step by step. Sometimes it’s just minor delays or small deformations in one spot that make the whole assembly difficult.
I can only confirm that. I just left the shelf in my living room, made sure the temperature and humidity were optimal, and after a day it was much easier to handle.
One more tip: Take your time – pressure and force are more likely to cause damage that will give you more trouble later on. And if you still can’t get it together: Sometimes it helps to slightly loosen a panel on the outside and realign the connections.
Don’t give up, it’s worth it! 🙂
