ᐅ Assembling KALLAX as a TV stand – is it unstable?
Created on: 10 Sep 2023 09:22
Katano
I am planning to assemble an IKEA KALLAX unit as a TV stand. Since I want to combine several KALLAX elements stacked and side by side, I’m wondering: how stable or wobbly is such a setup when used as a TV stand? I’m especially interested in whether the shelves are sturdy enough just with the included connectors, or if additional reinforcements are needed.
The issue is that my TV weighs about 15 kg (33 lbs) and is relatively large, and I also have other electronic devices that I want to place on and inside the unit. Can anyone with experience say if the stand becomes too unstable, especially when the KALLAX elements are stacked or combined? I’ve read that the individual shelves are quite stable, but when connected they can apparently become “wobbly.”
Also, I’d like to know if the unit should be anchored to the wall or if it is safe without wall mounting.
I look forward to your assessments and advice! Thanks in advance!
nubar
10 Sep 2023 11:55
Regarding stability:
The included fasteners are helpful but provide only limited support. To achieve a stable construction, I recommend the following measures:
- Use of wooden or metal brackets (e.g., L-brackets) at the connection points of the KALLAX units
- Additional back panels made from sturdy materials
- Securing to the wall with appropriate anchors and mounting brackets
This combination ensures significantly greater stability, especially when supporting heavy loads such as TVs and electronics.
Peose
10 Sep 2023 12:14
Hi Katano, last year I stacked two KALLAX units and used them as a TV stand – it works great! :-) It’s important that you firmly connect the units using the IKEA fasteners and additionally secure them to the wall with anchors.
I also have some cables and consoles inside, and it doesn’t wobble at all. I’ve even had a few people lean on it – no problem. So go for it! 🙂
GALEO4
10 Sep 2023 13:02
Katano schrieb:
Do you know, GALEO4, do you have experience with whether the stability can be significantly improved by adding your own braces or wooden battens?
Definitely yes. If you reinforce the joints from underneath and at the back with wooden battens, you create a proper load transfer. This prevents the individual modules from shifting against each other and keeps the entire structure from "floating."
With some basic carpentry skills, you can also make it look neat—for example, by installing the battens on the inside. This will definitely give you more rigidity than the standard connectors from IKEA.
Peose schrieb:
I also have some cables and brackets inside, and nothing wobbles.
That obviously shows that sometimes it works without professional bracing—but personally, I wouldn’t rely solely on luck.
Joe52
10 Sep 2023 14:00
I was also initially concerned about the stability of a KALLAX TV shelf. However, I read multiple times that wall mounting is strongly recommended, especially when stacking several KALLAX units on top of each other.
Once secured to the wall, everything is very stable, even if children run into it or items are rearranged on the shelf. If you have children, I would definitely recommend wall mounting.
In any case, you should use the IKEA connectors – mainly because they create a firm connection; otherwise, each unit will move independently.
kaubi
10 Sep 2023 15:22
A few technical notes on wall mounting:
Make sure to choose the appropriate anchors for the type of wall. For drywall, special hollow wall anchors are necessary, while for solid walls standard expansion anchors are sufficient.
The IKEA KALLAX wall brackets are quite simple in design but provide strong support when installed correctly. Additional stabilization is possible by installing metal brackets at the joints between the modules underneath.
The width of the installation area and the surface condition also play a role. On a flat, solid surface, the shelving unit is less likely to tip over.
Are you sure about the height of your construction? For three or more modules stacked vertically, I strongly recommend wall mounting.
Katano
11 Sep 2023 08:35
kaubi schrieb:
Are you sure about how tall your structure will be? If it’s three or more modules high, I strongly recommend wall mounting.
Thanks for the tip, kaubi! I’m planning two modules stacked vertically and two placed side by side—so a kind of wide, medium-height structure.
nubar schrieb:
Use wooden or metal brackets (e.g., L-brackets) at the joints of the KALLAX units
Sounds good! Could you maybe give some advice on the best way to fasten these brackets without making the shelf look unattractive? It could also be important considering cable management.
GALEO4 schrieb:
Supporting the joints underneath and at the back with wooden battens creates a real force transfer.
That appeals to me as well. Are there any recommendations regarding the material or dimensions? I want to ensure the shelf is stable all the way to the floor, with no creaking or movement.
