I recently noticed that the back panel of my IKEA KALLAX shelf is cracked in one spot—specifically at the lower right corner, where it is supposed to be held in place by nails or staples in the groove. The shelf itself remains stable, but the back panel no longer holds properly there and wobbles when bumped.
I’m curious to know how you handle a damaged back panel in such cases. Do you replace the entire back panel with a new one, buy spare parts from IKEA, or use replacements from third-party suppliers? Maybe some of you have repaired it using alternative materials that restore stability, such as thin MDF or plywood?
It would also be helpful to know how you reattach the back panel—is there a particular method or type of screws you prefer? I want the repair to be more than just a temporary fix; it should last in the long term.
Thanks for your experiences and advice!
Marlenepa31 Dec 2021 16:09Hello Girupu,
I am very familiar with the problem of the KALLAX back panel. This thin hardboard is unfortunately quite fragile and breaks easily, especially at the corners.
My recommendation is to replace the entire back panel if the damage is that severe. Although you can't buy a single replacement back panel from IKEA, there are suitable alternatives available at hardware stores. I usually go for a 3mm (1/8 inch) thick MDF board, which I have cut to the size of the shelving unit.
To attach it, I use small nails intended for picture frames or small furniture clips. It’s important to support the panel while nailing it in to prevent further cracking. Another option, if you want something more stable, is to use small screws with anchors inserted into the edges of the shelf.
Additionally, you can apply some wood glue before nailing to improve the hold.
If you’re handy, you can also fill in the damaged area with wood filler and reinforce the back panel from behind with a thin wooden board. This makes it particularly sturdy, although it requires a bit more effort.
I hope this helps you!
Girupu schrieb:
I am therefore interested in how you deal with a damaged back panel in such cases.
Girupu schrieb:
I am also interested in how you reattach the back panel.
Marlenepa schrieb:
My recommendation is to replace the entire back panel if the damage is that severe.This is a technically correct approach. The original KALLAX back panel is made of a thin hardboard particle board, about 3 mm (0.1 inch) thick, which tends to break easily at the corners under stress.
Regarding the materials:
- MDF boards are indeed a suitable alternative, as they are more stable and less brittle. A thickness of 3 mm (0.1 inch) makes sense to keep the original dimensions.
- Plywood sheets can also be used; however, it is important to choose thin birch or beech plywood to avoid warping or excessive stiffening of the shelf.
Regarding fastening:
- Fine nails are common but can damage the new panel again if too much pressure is applied.
- Alternatives include small screws with hollow wall anchors or, if accessible, side clips that fit into the grooves of the shelf sides.
- Wood glue is more of a secondary measure and alone is only partially sufficient for stabilization.
I recommend taking the exact measurements of the back panel before purchase and possibly contacting a hardware store with a cutting service. Professional installation significantly increases durability.
I would not recommend a temporary fix using glue or provisional stapling.
In addition to the material, it should also be checked whether the shelf is still level to avoid tensions.
Friedrich2 Jan 2022 18:58Girupu schrieb:
I don’t want the repair to be just a temporary fix, but to last in the long term.I completely understand. I felt the same way when the back panel of my KALLAX broke. At first, I tried just gluing the broken part, but it was never really stable.
I ended up replacing the entire back panel and reinforced the corners from the outside with thin aluminum angle brackets (from the hardware store). It took a bit more effort, but now everything holds very well.
Sometimes the extra work is worth it, especially if you use the shelf a lot or it carries weight.
I wish you good luck with your repair and hope you find a solution that keeps you satisfied in the long run! 🙂
