ᐅ Kallax as an Aquarium Stand – Playing It Safe?
Created on: 2 Apr 2023 08:23
Tarklo
I am planning to place my new aquarium on an IKEA Kallax shelving unit and have an important safety question: Is the Kallax sturdy and strong enough to safely support a water-filled aquarium without causing structural issues, deformation, or even risks of collapse?
I understand that the Kallax is originally designed for books and other much lighter items, so I am wondering if there are technical specifications, practical experience, or special precautions to ensure it is fully safe. What should I pay particular attention to, for example regarding the maximum load capacity of the shelves, possible reinforcements, or the correct way to distribute the weight?
I look forward to your assessments, experiences, or advice – thanks in advance!
meGreg
2 Apr 2023 13:26
Ianlau schrieb:
"... only with additional reinforcements and careful inspection."
Exactly! 🙂 That’s why I’d recommend, Tarklo, placing a plywood sheet as a base under the tank and then reinforcing the inside of the shelf with brackets or wooden battens.
And if you want, you can add rubber pads to provide some cushioning and weight distribution.
It might sound like a lot of work, but this way your whole setup will be more stable – plus, Kallax looks great anyway, so you can make it stylish!
FLONE41
3 Apr 2023 07:54
I really appreciate how many of you are already sharing your experiences! As someone who is also very concerned about damage or accidents, I can only emphasize that "playing it safe" is truly important.
From my side, I’d like to add that not only long-term load capacity is crucial, but also moisture. Kallax is not water-resistant and tends to absorb moisture – this leads to faster aging.
So if you don’t use a professional wood sealant, it’s best to protect the Kallax with a waterproof panel.
meGreg schrieb:
"... With rubber pads ... cushioning and distribution ... your entire setup just chills."
That definitely makes sense, but I’m a bit cautious about the aquarium tipping if the base is soft. A fixed structure seems safer to me.
draFrederi
3 Apr 2023 09:23
Hi, I’ll jump in briefly as well – Kallax is a great piece of furniture, but honestly, for aquariums without additional measures, it’s not ideal.
I once placed a 54-liter (14-gallon) tank on it (similar to Ianlau’s), and it held up fairly well with reinforcement and a horizontal base, but my gut feeling is: better to prepare thoroughly.
The effort is worth it because, despite all precautions, there is a risk that the particleboard can warp or swell due to moisture.
This is especially true for larger aquariums, which often hold 100+ liters (26+ gallons); the usual Kallax shelves quickly become critical.
So: it’s better to work with sturdy boards and strong connections right from the start – this way you protect your fish and, above all, yourself from unpleasant surprises.
te-min
4 Apr 2023 08:33
Kallax alone is not strong enough without reinforcement.
Place a plywood board on top, secure the sides with brackets, and use a spirit level.
For larger aquariums, it is better to use a specialized piece of furniture.
BAUEVA
4 Apr 2023 09:47
te-min schrieb:
"Place a plywood board on top, secure the sides with brackets, use a spirit level."
That’s definitely the practical solution.
However, I would add: depending on the condition of the base, distribute the entire load with an additional support board underneath the Kallax.
This prevents point loads on the furniture and protects against unwanted warping.
