ᐅ KALLAX and Tropical Humidity – Is It Durable?
Created on: 6 Feb 2019 09:12
Lado0
I am planning to install an IKEA KALLAX shelving unit in a tropical environment, specifically in a living area that consistently has high humidity levels of around 70 to 80%. I am wondering if this constant tropical humidity could damage the MDF material of the KALLAX shelves – for example, causing it to swell, permanently warp, or possibly lead to mold growth.
Does anyone have experience with KALLAX or similar shelving units exposed to consistently high humidity? Are there any special coatings or protective measures that should be taken to ensure long-term durability?
I look forward to knowledgeable and practical feedback!
sihau
6 Feb 2019 14:23
As an addition: MDF absorbs moisture amounting to approximately 8 to 13% of its weight, which increases at 70-80% relative humidity. The resulting swelling can vary between 5 and 15%.
Paints or coatings can make the surface water-repellent but not completely impermeable to water vapor.
Recommendation: a multi-layer application of polyurethane clear coat (at least 2-3 layers) is well suited, as it is abrasion-resistant and water-repellent. Stains, on the other hand, penetrate the wood and provide less protection against moisture than thick layers of paint.
Good ventilation and avoidance of direct moisture condensation are also essential.
Lisele
6 Feb 2019 15:11
I can understand that the topic is worrying, especially with tropical humidity. It is really unfortunate when the furniture suffers due to important climate conditions.
Sometimes it helps to deliberately raise the furniture a bit, for example with small feet or pads, to keep ground moisture away and allow air circulation.
I would also check whether the wood has already developed mold or smells musty – that would be a warning sign. But as a precaution, treating it with clear varnish and ventilating regularly seems to me the best compromise 🙂
Lucki
6 Feb 2019 15:36
Hey,
“This is brilliant!” It’s amazing how many tips have already been shared here! :-)
A small addition: If you protect the shelf edges and screw joints well with clear varnish, you can strengthen these areas against moisture—edges tend to swell the fastest. Even after the shelf is assembled, you can touch up these spots with small brushes.
Also, consider using moisture absorber bags or even small electric dehumidifiers in the room. This is often easier to manage than expected and will also help preserve the furniture. Good luck!
NEREO
6 Feb 2019 16:03
KALLAX is not designed for high humidity.
Better-suited furniture is made of solid wood or metal.
Do not use without protective measures in tropical humidity.
Lado0
7 Feb 2019 08:27
sihau schrieb:
"Polyurethane clear coat (at least 2-3 layers) works well because it is abrasion-resistant and water-repellent."
Very helpful, thank you!
Are there any product recommendations or specific manufacturers that have proven reliable for polyurethane clear coats, especially for MDF and high-humidity environments?
NEREO schrieb:
"Better-suited furniture would be made of solid wood or metal."
Unfortunately, my storage needs are quite large – so a metal shelf would seem rather too "clinical," and solid wood is difficult within my budget.
So I am still considering how to best protect the KALLAX.
What do you think about placing the KALLAX next to a dehumidifier and treating it with a clear coat? #Prevention
