ᐅ My KALLAX unit is placed on a radiant floor heating system – any impact?
Created on: 17 Apr 2024 08:37
Liko10
Hello everyone, I have a somewhat specific question: My KALLAX shelf is placed exactly on the spot in my apartment where there is underfloor heating. What long-term effects could this have on the furniture?
I’m asking because the shelf is standing directly on the floor, and I’m concerned whether the wood or wood-based panels might warp or even get damaged due to the heat. Does anyone have experience with the combination of underfloor heating and furniture placed directly on top of it? Are there any special recommendations or warnings I should be aware of?
Thanks in advance for your insights!
mauka
17 Apr 2024 12:13
Liko10 schrieb:
If anyone has tips on which materials are especially suitable
I would suggest thin felt pads or cork mats. Cork has the advantage of being insulating while still breathable, so it doesn’t trap moisture. Felt is also great but might not contribute as much to thermal insulation.
The whole point isn’t to create a barrier, but just to slightly reduce heat transfer while also preventing scratches. 🙂
kieran
17 Apr 2024 13:37
To objectively assess the effects of underfloor heating on furniture components such as the KALLAX system, the following points are crucial:
1. Maximum surface temperature: Underfloor heating in living areas should not exceed 29-31°C (84-88°F) according to DIN 4725 and EN 1264, which is not critical for wood-based materials.
2. Wood-based materials like chipboard and MDF have low thermal conductivity, so heat is not directly transferred.
3. Prolonged heat exposure can cause warping or swelling in lower-quality coatings; however, this depends on the material and quality.
4. Recommendation: A thin, vapor-permeable insulation underlay protects the furniture from direct heat transfer and prevents stress.
Conclusion: For the KALLAX, which mainly consists of laminated chipboard, no significant damage is expected from typical underfloor heating temperatures if used properly.
nolan
17 Apr 2024 15:22
If possible, keep a gap between the shelf and the floor. Insulate at least 1-2 cm (0.4-0.8 inches) or use a protective mat.
This helps prevent direct heat exposure and moisture problems.
Ramon4
18 Apr 2024 08:03
Hello Liko10,
I often manage apartments with underfloor heating and furniture made from wood-based materials. In my experience, most furniture pieces do not cause problems as long as the temperature does not get too high.
It is important that the underfloor heating does not maintain very high temperatures continuously but stays at a moderate level. Occasional heating up is not an issue. Also, make sure that no moisture from condensation gets under the furniture.
A thin layer of insulation or felt is useful to buffer heat and moisture.
Good luck!
mauka
18 Apr 2024 09:25
Exactly! And if you also place a small spacer under the shelf, it prevents moisture buildup and allows air circulation – which keeps everything healthy. A bit of DIY creativity, sometimes that’s all you need 😉
Greglau
19 Apr 2024 07:44
In brief:
- KALLAX is stable under normal underfloor heating temperatures.
- Direct contact increases the risk of slight deformation or discoloration.
- Protection with felt or cork is recommended.
No more, no less.
