ᐅ KALLAX as a DIY Aquarium Cabinet – Risk Assessment?
Created on: 19 May 2019 10:23
danmin
danmin
19 May 2019 10:23
I am currently considering placing my new aquarium on a modified IKEA KALLAX shelf unit as a stand. However, I am concerned about the specific risks involved. The KALLAX modules are not originally designed to support heavy loads or to withstand prolonged exposure to moisture. My main question is how stable such a DIY setup truly is when holding several hundred liters (hundreds of gallons) of water, and whether the wood or panels might be damaged over time by water vapor.
Additionally, I am interested in how you address waterproofing, structural stability, and possible reinforcements. What mistakes should be absolutely avoided when using a KALLAX as an aquarium stand in a DIY project, and what experience do you have on this? Are there any general risks that are commonly overlooked?
I would appreciate well-informed opinions and assessments!
Shawn38
19 May 2019 11:02
Hello danmin,
First of all, a good topic! KALLAX is versatile, but as you mentioned, it’s not specifically designed for aquariums. Basically, you should keep in mind that the weight of a large aquarium is very high, especially at concentrated points. The KALLAX compartments are actually intended for lighter loads.
It is important to distribute the load over as many elements as possible and to avoid bending. It is often recommended to reinforce the shelf carcass with additional panels, especially at the top where the aquarium sits.
The moisture issue should not be underestimated either: the panels are veneered and not waterproof. The only solution is a carefully applied sealant, for example epoxy resin or something similar.
Another thing many overlook is placing support plates or a sturdy base plate under the aquarium to distribute the load even better.
So your project is doable, but there are some technical aspects to consider, otherwise consequential damage could occur very quickly.
naujon
19 May 2019 11:45
Hello danmin,
I would like to organize this a bit and address potential risks when using KALLAX as a DIY aquarium stand:
1. Structural integrity and load capacity: The KALLAX units have a maximum load, usually around 13-15 kg (29-33 lbs) per shelf. The weight of an aquarium (water + equipment + decorations) often exceeds 200-300 kg (440-660 lbs). This means you need to connect multiple compartments and reinforce them with bracing.
2. Moisture: The panels are laminated but not waterproof. Condensation or small splashes can cause swelling over time. Recommendation: fully seal the unit or use a waterproof base.
3. Warping: Since this furniture is not designed for heavy loads, it can warp. This affects stability and potentially the aquarium (glass is especially sensitive to this).
4. Construction: Additional reinforcements such as metal brackets, cross braces, and a solid base plate made of, for example, plywood, significantly improve safety.
5. Safety: Make sure the surface underneath is completely level and stable, as even a slight slope can cause significant stress on the aquarium glass.
Conclusion: It is possible, but requires some DIY skills and careful planning. Take your time during assembly and regularly check stability!
putan
19 May 2019 12:17
Hey danmin,
I really like the idea of using the KALLAX – Ikea plus an aquarium, that already sounds like a dream DIY project ;-)
But honestly: the risk is definitely not negligible. Especially moisture can be the hidden enemy. I remember my KALLAX developed small cracks in the laminate after a few years, even without an aquarium. When water gets in, the parts swell like yeast dough in the sun 😄
What you could do:
- Place a waterproof panel (e.g. plywood, plastic) on top
- Seal all edges with sealant
- Maybe install supports made of wood or metal to better distribute the load
This way, the KALLAX turns from a simple piece of furniture into a sturdy base for your tank.
Good luck and keep safety in mind! 🙂
enrique7
19 May 2019 13:05
Shawn38 schrieb:
KALLAX is versatile, but as you said, not specifically designed for aquariums.
That’s a crucial point. When it comes to DIY furniture like this, I always wonder: Is there really a safe, scientifically validated method to account for the structural stability and long-term load bearing with water? Often, people rely on manufacturer specifications that have no relation to aquarium loads.
naujon schrieb:
The KALLAX units have a maximum load capacity – usually around 13–15 kg (29–33 lbs) per shelf.
I find that concerning because the total load isn’t just the static weight – there are additional dynamic factors such as shocks, small movements, or vibrations.
Furthermore, as mentioned several times, moisture will weaken the material integrity over time. Who can confirm that a properly sealed KALLAX structure will actually remain stable for several years? My skepticism is that repair and replacement costs might eventually outweigh the benefits.
Of course, it’s a cool project, but I advocate for a realistic assessment rather than just a makeshift solution.
danmin
19 May 2019 14:28
Shawn38 schrieb:
It is important to distribute the load across as many elements as possible and to avoid deflection.
That is exactly my main point. I have already taken the shelf apart and am currently planning how best to reinforce it with cross braces and possibly metal brackets.
naujon schrieb:
Make sure the base is absolutely level and stable
That’s also a good point. However, the floor (screed) is not perfectly level, so I am considering using small leveling shims.
putan schrieb:
Place a water-resistant board (e.g., plywood, plastic) on top
Plywood sounds reasonable, but doesn’t that significantly increase the overall weight again?
enrique7’s concerns are certainly understandable, but I’m trying to make the whole thing as safe as possible with materials and reinforcements. Still, it’s good that you point out the critical issues again, as it motivates me to plan thoroughly.
