ᐅ KALLAX as a Workshop Shelf – Should We Secure It for Heavy Loads?
Created on: 13 May 2018 10:07
Paumar
I have been considering using an IKEA KALLAX shelf as a workshop shelf in my garage for some time. It will mainly hold tools, small machines, and materials – so it will sometimes be quite heavily loaded. Now I am wondering whether I need to secure the KALLAX to the wall to ensure stability and safety for this kind of use, or if it is sufficient to place the shelf freestanding.
Does anyone have experience with how much weight the individual compartments can bear without the shelf tipping over or sagging? And how effective are wall mountings for this type of shelf? Are there any special fixing methods or recommendations I should consider to minimize the risk of tipping or damage to the shelf?
I look forward to your expert advice and opinions!
Paumar schrieb:
I’m also interested if anyone has recommendations on how to make wall mounting as visually unobtrusive as possible?A fairly invisible solution is to use small, flat brackets painted to match the color of the shelf. You can screw these directly to the top of the back and anchor them into the wall using appropriate anchors.
Alternatively, slim and sturdy aluminum bracket profiles can help; these often come powder-coated in white, making them hardly noticeable.
A small tip: adjust the color beforehand a bit, so they really blend in and stay almost invisible.
As an additional note: I absolutely cannot recommend attaching fasteners only at the bottom of the cabinet. Ideally, screws should be placed in the upper area, as this is where the risk of tipping is greatest.
The brackets should be at least 20 mm (0.8 inches) thick to provide sufficient support, even at small angles. When choosing wall plugs, always consider the load-bearing capacity of the wall.
Danabla schrieb:
Screws are best placed in the upper area because that is where the risk of tipping is highest.Thank you, that makes sense. I will implement it that way.
Does anyone have experience with installing these fastenings without pre-drilling in timber stud walls, or is it always better to use anchors and drill holes? In my case, the wall consists of an OSB wood panel attached to the wall frame.
When working with OSB boards, it is generally best to use pre-drilled holes and suitable wood screws. I would not recommend mounting heavy loads on drywall without studs unless appropriate anchors are used.
Fastening to load-bearing studs is of course the best option when possible. Alternatively, a multi-purpose anchor with a high load capacity can be used.
