I am considering using an IKEA Kallax shelf unit as a countertop replacement to create a kind of bar in my small kitchen. However, I have a question: Is a Kallax shelf stable and strong enough to function as a countertop, especially when I sit on it or put heavier loads on it?
I know the Kallax seems fairly sturdy, but it is not a typical piece of furniture designed for a bar counter, which often has to withstand a lot. Has anyone had experience using the Kallax as a countertop?
How about the weight capacity on the shelves if the unit is also used as a seating area/counter? And what would be the best way to secure or reinforce the shelf if its original stability is not sufficient?
Thanks for your tips and experiences!
Hello kihanna,
your question about using the Kallax as a counter is very well formulated, and I understand the uncertainty. I have personally used a Kallax as a bar counter and can share my experience with you:
The Kallax is not primarily designed to serve as a counter, especially when used as seating furniture (with stools in front). Its stability is sufficient for moderate loads, meaning you can easily place plants, books, or dishes on it. However, if you want to sit on it, you need to be careful. The shelf can bend if the load is uneven.
It is important to properly install the back panel and securely attach the shelf to the wall – this greatly improves stability. Additionally, you can add further reinforcements, for example, a thin wooden board on top fixed with angle brackets.
All in all, you can use the Kallax as a counter if you don’t overload it or need it to be mobile. I would not recommend sitting on it regularly to avoid material fatigue.
If you need more details, please let me know!
Ixvin schrieb:
The shelf itself can sag if the load is not evenly distributed.Exactly, that is a key point.
First, about the construction: The Kallax system is designed by IKEA primarily as a static structure. It basically consists of medium-density fiberboard (MDF) with a melamine-coated surface. The load capacity IKEA specifies is usually around 13–15 kg per shelf and about 50 kg for the entire unit – of course, only if everything is evenly distributed and properly assembled.
If you want to use the Kallax as a counter, there are two main aspects to consider:
1. The horizontal load on top of the unit.
2. The dynamic load, for example when someone leans on it or uses it for support.
The latter can become problematic without additional reinforcement. If you plan to use it as a seating area or for more intensive support, I recommend this technical approach:
- Securely attach the unit to the wall using heavy-duty angle brackets. This prevents tipping and increases stability.
- Place a sturdy countertop on top, preferably made of solid wood or laminated chipboard, fastened to the side panels of the Kallax with strong screws.
- Optionally, you can install cross braces made of metal or wood inside to reinforce the frame structure.
- If the load becomes very high (e.g., as a sitting counter with stools), it might be advisable to add extra legs or supports under the countertop that rest directly on the floor.
kihanna schrieb:
...What about the weight that can be stored on the shelves...?For simple storage in the compartments: 13–15 kg per shelf seems realistic to me. You should avoid storing heavy kitchen appliances or large water containers there.
If you want more details about the modification or a building guide, just let me know, I have documented it quite thoroughly.
I would like to add a few points to this topic, as I recently faced exactly this question myself.
Using Kallax as a counter is a clever idea because the shelving system is modular and easily adjustable. However, there are important aspects to consider:
1) Choosing the countertop / work surface
The original shelves are not designed to serve as a countertop. Often, a sturdy additional wooden board or even a thin plywood panel placed on top of the shelf and screwed in is sufficient. But be careful: the board should extend beyond the shelf edges and be firmly secured to prevent shifting.
2) Stabilizing the shelving unit
What is really essential is attaching special angle brackets to the wall and inside the shelving unit – this protects the system from twisting. This is especially important if someone leans on it or occasionally sits on it.
3) Load and use as seating
Kallax is not intended as seating furniture. If you want to sit on it, additional reinforcements and supports should be installed. Otherwise, stability is quickly lost and the structure can be damaged.
I have also had good experiences with attaching stools that have adjustable feet to ensure the weight is always well distributed.
Summary: For occasional use as a counter with storage, Kallax is usually sufficient, but for permanent heavy use, especially as seating, further reinforcements are essential.
Hope this helps! 🙂
Hope this helps! 🙂
