ᐅ Using a Kallax as a Workbench – Load-Bearing Capacity for Heavy Tools?
Created on: 5 May 2023 08:23
Gebhardfl8
Gebhardfl8
5 May 2023 08:23
Hello everyone, I’m currently considering using an Ikea Kallax shelf as a workbench. More specifically, I’m wondering how sturdy a Kallax really is when placing relatively heavy equipment on it, such as a sewing machine, possibly a small lathe, or even a larger printer.
Does anyone have experience with how stable the shelf is as a tabletop? I’m particularly interested in whether the structure can reliably support the weight without warping or becoming unstable – even with somewhat dynamic use, like when working more forcefully.
Does anyone have tips for reinforcement or know of potential weak points? I want to avoid unnecessary damage while creating a cozy, practical crafting setup. Thanks in advance for your feedback!
barle
5 May 2023 08:36
Hello, a Kallax is not designed for heavy loads. For heavy machines, you should definitely use an additional sturdy board and reinforce the structure. Without reinforcement, it will quickly become unstable.
Timmyse36
5 May 2023 09:02
I completely understand the feeling of building something yourself and then hoping it will hold up. Although I’ve only used my Kallax for lighter items, I can imagine it’s not a permanent solution for heavy equipment. Maybe you’ll find some good ideas here on how to optimize it as simply as possible 🙂
Danial
5 May 2023 09:15
Here is my perspective: Without specific information about the load, the question doesn’t make much sense. How heavy exactly are the devices? According to Ikea, a Kallax shelf can hold up to about 13 kg (29 lbs) per compartment. However, this is a static load and not intended for a work surface with dynamic loads.
Moreover, the stability is largely influenced by the connection between the shelf unit and the tabletop. Without additional reinforcements—such as metal brackets at the edges or a thicker plywood panel as a support—a Kallax used as a workbench for heavy equipment is rather risky.
bupar
5 May 2023 09:41
Technical clarification: Kallax is made of MDF panels and has a maximum static load capacity per compartment of about 13 kg (29 lbs), as mentioned by Danial. The top surface, which is often made of thinner particleboard or MDF, is not specifically designed as a work surface and tends to sag under point loads.
To reinforce it, frames made of plywood or laminated timber can be mounted on the top panel. Alternatively, metal brackets or additional cross supports can be installed. I also recommend partially removing the shelves to install a more stable work surface.
Gebhardfl8
5 May 2023 10:02
Thanks in advance for the initial assessments!
Regarding the weight issue: My sewing machine weighs about 6 kilograms (13 pounds), the smaller lathe around 15 kilograms (33 pounds), plus accessories and possible additional weight from a printer, etc. So we are generally talking about 20 to 30 kilograms (44 to 66 pounds) resting on the surface. Also, I don’t just want to sit there doing light tasks but occasionally handle something with some force.
Therefore, reinforcement is important to me – what exactly would you recommend to keep the table stable even during movement? By metal brackets, I mean actually reinforcing the cabinet sides directly, right? Are there any proven DIY solutions? And how do you handle the worktop – do you use something different from the original part?
