ᐅ KALLAX used as a console in a narrow hallway – how do you attach the doors?
Created on: 19 Aug 2024 08:37
Leonau46
I have a question and hope to benefit from the community’s experience: I am planning to use an IKEA KALLAX as a console in my very narrow hallway. The available floor space is limited, but ideally, I want to attach doors to it to neatly store items like shoes, bags, and similar things behind them.
My specific question is: How do you attach doors to a KALLAX when it is placed in a tight corridor with little space for opening? Do you use special hinges, magnetic catches, or other clever solutions to prevent the doors from sticking out or getting in the way when walking past?
Any tips on attachment methods, door-opening mechanisms that work well in narrow hallways, or additional measures such as alternative handles or the use of sliding rails would be very much appreciated.
Thanks in advance for your advice!
Nabla64
20 Aug 2024 10:22
I would like to respond to and add to Palenar’s detailed post:
If the front door frequently hits the KALLAX door, I recommend using safety edge protectors or self-adhesive cushioning pads. These absorb impacts effectively and prevent damage to the wood or paint.
Alternatively, you could install soft-close hinges, which use a hydraulic mechanism to slow the door during closing, reducing the impact noise. This is especially useful in narrow hallways, where it prevents slamming and increases durability.
If fitting door handles is not possible, recessed grip pockets can also be integrated to minimize the clearance needed for handle movement.
Marcellela
21 Aug 2024 11:37
If possible, always try a temporary installation first.
Usually, you only realize if doors work well in tight spaces when you realistically test the available movement space.
Even a quick test using tape can help simulate the swing area before installing expensive hinges.
Leonau46
21 Aug 2024 12:08
Marcellela schrieb:
If you can, definitely try a temporary assembly beforehand.
Very good advice! I will do just that. Thanks to everyone who has contributed so thoroughly here. I will take a close look at and test the insights on hinges, push-to-open mechanisms, magnets, and dampers.
If anyone has valuable recommendations regarding specific screw lengths or door reinforcement in narrow hallways, please share. So far, your feedback has been really helpful!
