ᐅ Is there a simple way to oil IKEA BESTA drawers?
Created on: 23 Jan 2022 08:37
Nauken
Nauken
23 Jan 2022 08:37
Good morning everyone, I have recently started maintaining my IKEA Besta drawers. I’m wondering if there is a simple way to oil the drawers from the BESTA series effectively, so that smooth operation and functionality are preserved for a long time without having to completely remove the full drawer slides or invest a lot of effort. I have read that some oils or lubricants are not suitable because they attract dirt or become sticky. At the same time, I want to avoid too much work, such as dismantling and complicated cleaning. So, is there an easy, practical way to oil these drawers properly and maintain them in the long term? Looking forward to your tips and experiences!
daalessio
23 Jan 2022 09:12
One of the most effective methods is actually using silicone spray or Teflon spray. They do not leave a sticky residue, do not attract dust, and are therefore ideal for furniture fittings.
It is important, if possible, to remove the drawers so the spray can reach all the relevant areas, especially the runners and rollers. Afterward, open and close the drawers several times to ensure the lubricant spreads evenly.
There is no need to remove the runners; often just pulling out the drawer is enough. Additionally, this method is quick and clean.
Ryder35
23 Jan 2022 09:45
Silicone spray is the best choice. Simply spray a mist onto the tracks or rollers, move the drawers back and forth several times, and you're done.
naujon
23 Jan 2022 10:25
A brief guide on how to properly maintain and lubricate BESTA drawers:
- Pull the drawer fully out and tilt it slightly to make the tracks easily accessible.
- Use a lint-free cloth to remove any visible dirt, as oil does not work well on dirty surfaces.
- Apply silicone spray sparingly, not too much.
- Reinsert the drawer and open and close it several times to distribute the lubricant.
- Wipe off any excess oil with a cloth to prevent dripping or attracting dirt.
A common mistake is using regular oil or WD-40, which often becomes sticky and attracts dust. Silicone spray is definitely the better choice here.
PLOMA
24 Jan 2022 07:16
Let me go into a bit more detail here, as the question is quite complex.
IKEA BESTA drawers run on sliding rails, usually ball-bearing or roller-type guides. These typically combine metal and plastic components. Therefore, the type of lubricant used is a crucial factor:
- Regular oils, such as machine oil or cooking oil, are unsuitable because they oxidize over time, become sticky, and attract dust – leading to dirt buildup and sticky residues.
- WD-40, while providing some care, is essentially a penetrating oil with solvents and is better suited for cleaning and loosening than for long-term lubrication.
- Teflon or silicone sprays are ideal for this application: they are non-sticky, water-repellent, keep dust away, and reduce friction.
Application:
1. Fully extend the drawer. If possible, remove the sliding rail, though this is usually not mandatory.
2. Clean the rails – ideally with isopropanol or denatured alcohol to remove old dirt.
3. Apply a thin layer from every angle of the sliding guide.
4. Carefully slide the drawer back in and open/close it several times to ensure even distribution.
Question for the original poster: Are your drawers squeaking, or are they sticking? If the latter, cleaning dust and dirt from the rails before lubricating might be necessary.
I generally recommend paying attention to additives in the lubricant, as aggressive solvents could damage plastic parts. The sprays mentioned are usually plastic-compatible, but you should verify this.
Nauken
24 Jan 2022 08:44
PLOMA schrieb:
Question to the original poster: Are your drawers squeaking or sticking? If it’s the latter, cleaning the drawer slides from dust and dirt might be necessary before lubricating.
Thank you for the detailed explanation! The drawers do occasionally squeak. The noise mainly occurs when opening them. So far, I haven’t noticed any significant dust or debris, but it’s possible. I haven’t cleaned them yet because I was hoping that simply applying lubricant could solve the problem.
In this case, should I still clean them first (for example, with isopropyl alcohol) before using silicone spray or PTFE spray? Or is it sufficient to apply the spray directly? I would prefer the latter to keep the effort as low as possible.
