ᐅ Is there a way to quickly swap the fronts on IKEA Metod kitchen cabinets?
Created on: 7 Dec 2017 07:42
Gurasu
Hello everyone, I have a question regarding my current kitchen planning with IKEA Metod: Is there a way to quickly and easily change the cabinet fronts without having to dismantle the entire kitchen project or spend a lot of time on it? I am especially interested in whether there is any practical mechanism or special design that makes this process easier. I would appreciate any experience reports or tips on handling this, as I plan to occasionally change the look of my kitchen.
Gurasu
7 Dec 2017 14:45
Neogi schrieb:
That’s basically true, but you should keep in mind that not all Metod fronts are the same.
Thank you for the advice, that makes sense. My kitchen features different types of fronts, such as drawers, glass doors, and classic doors. Are there differences when replacing the fronts between these types? Are there any special considerations for glass fronts to avoid damaging the hardware?
difepeo
7 Dec 2017 16:33
Gurasu schrieb:
Are there differences when replacing the fronts on these types?
Yes, especially with glass fronts, caution is necessary. Unlike wood or MDF, glass fronts are heavier and often secured with additional reinforcements or specialized fittings. This usually means more effort is required for removal and installation. Some experience in handling glass is also recommended to avoid damage. For drawers, different clips are generally used compared to doors, as the front is often partially screwed on.
NUGRANT
8 Dec 2017 08:10
I really like the easy front panel replacement with IKEA Metod! 😍 Some time ago, I changed the fronts myself, and it was much faster than expected. The clip systems are especially well designed. For anyone who wants to refresh their kitchen look more often, it’s a great solution! It’s fun and encourages creativity.
fepau
8 Dec 2017 12:29
NUGRANT schrieb:
I really like the simple front replacement with IKEA Metod!
Absolutely! I just refreshed my kitchen with new fronts, and it was really easy. Plus, it lets you try out new colors more often and reinvent your kitchen. So go for it, everyone! 👍
ronti
8 Dec 2017 15:42
For a quick front panel change with Metod, I recommend following the assembly instructions carefully and gently releasing the clips. Usually, no tools are needed with newer models, but for older ones, a screwdriver should be used. Pay attention to the handle attachments!
lochen
9 Dec 2017 10:51
One final tip: If you frequently change fronts, it might be helpful to gradually document the differently attached parts, for example with notes, so you know exactly how the parts are mounted next time. Storing clips and screws in separate containers also prevents trouble. Care for the materials and careful removal are essential.
