ᐅ Is there a way to protect Ikea PLATSA furniture from pet scratches?
Created on: 6 Nov 2015 18:37
ahmed37Hello everyone, I own several Ikea PLATSA furniture pieces, which I really appreciate because of their flexibility and design. However, I have a problem: my cat likes to scratch these pieces, which unfortunately leaves noticeable marks on the surfaces. Now I am wondering if there are effective ways to protect the Ikea PLATSA furniture from scratches caused by pets like cats or dogs? I am especially interested in protective measures that can be easily applied to the furniture but still work reliably without significantly affecting the appearance. Does anyone happen to have experience with suitable protective films, special treatments, or other practical solutions? Does the construction of PLATSA furniture support or hinder certain protection methods? Any ideas or experiences would be very helpful to me, thanks in advance!
Basically, Ikea PLATSA furniture is made from coated particleboard, which means it has a smooth surface but is not particularly scratch-resistant. To protect this furniture from pet scratches, I recommend the following measures:
- Apply a transparent protective film designed specifically for furniture surfaces. This can be scratch-resistant and is relatively easy to install.
- Use plastic or metal corner and edge protectors on areas that are heavily used.
- Additionally, you can use scents or special sprays here and there that deter cats from scratching these spots, although their effectiveness varies individually.
The material construction affects the choice of protective measures in that harsh cleaning agents or adhesives should be avoided because they can damage the surface. A protective film must be thin enough to be visually unobtrusive but durable enough to provide mechanical protection. If a permanent solution is desired, a self-adhesive film with a matte or glossy surface is also an option, which can be easily replaced. Other covers like glass or acrylic sheets are possible but significantly change the appearance.
[@KAMERON, post: l5t2s2, member: XXX]
Basically, Ikea PLATSA furniture is made from coated chipboard, which means it has a smooth surface but is not very scratch-resistant.
This is an important point I want to add: the PLATSA series uses a melamine resin coating that is resistant to moisture and minor impacts but can scratch easily from strong mechanical forces like claws.
Regarding applying protective films, there are differences in adhesive strength and thickness. A film with high hardness (e.g., over 200 micrometers) offers better protection but can result in visible edges. Films made specifically from polyurethane are recommended as they are flexible and self-healing, meaning they can close small scratches. When applying, a dust-free surface and careful air bubble removal are essential to prevent the film from peeling at the edges, which would allow dirt to get underneath.
Another technical option is using plexiglass or acrylic sheets, which can be placed on or screwed onto the furniture. This solution works especially well for horizontal surfaces or fronts because the material is extremely scratch-resistant. However, it is more visually noticeable and requires precise cutting. Additionally, the attachment should be removable for furniture cleaning or modifications.
Regarding deterrents: there are pet-repellent sprays with pheromones or bitter substances, but their effect is often only temporary since animals can get used to them. Therefore, I would rely on mechanical barriers (films, protective panels).
Can you specify on which furniture parts (fronts, sides, shelves) the scratches occur most frequently? That way, more targeted protection suggestions can be made. How severe are the issues – are they light marks or deep claw scratches?
I can relate to this issue very well since I am a cat owner myself and have often faced similar challenges. With Ikea PLATSA furniture, I have had good experiences over time using a combination of these approaches:
- First, we applied transparent adhesive films from the hardware store to the areas that are most commonly scratched (e.g., doors and edges). These films are not perfect but provide a significant barrier.
- At the same time, I placed several scratching posts and mats in the room that are more attractive to the cat than the furniture. Especially scratching posts with sisal ropes often prevent cats from damaging furniture.
- Additionally, we have been using catnip sprays on the allowed areas for several months to redirect the cat’s positive attention.
- In case you’re interested: Some users recommend protective panels made of glass or plexiglass that can be placed on the furniture. This works well if you can accept the change in appearance.
One more tip: Check if your pet’s claws are too long, as trimming the claws often reduces scratching behavior and thus damage to furniture.
If you want, I can provide more detailed advice on how to specifically re-train cats indoors – this is often the most sustainable solution.
