ᐅ Is there a way to assemble Ikea Hemnes furniture without visible screws?
Created on: 7 Apr 2018 09:17
DraroHello everyone,
I am planning to assemble an Ikea Hemnes furniture piece soon, and I was wondering if there are any ways to build it without having the screws visible from the outside?
It’s not just about the aesthetics—making the furniture look as clean as possible without visible screws—but also about whether there are practical solutions to avoid or at least cover the conventional screw system.
Are there special screws, caps, alternative fastening methods, or handy techniques that actually work in practice and remain stable?
I don’t want to risk reducing the stability, but at the same time, I don’t want the usual "Ikea look" with visible screws and holes everywhere.
What are your experiences? Are there generally recommended approaches or known tricks to assemble the Hemnes without visible screws?
Thanks in advance for your constructive tips and opinions!
Draro schrieb:
Are there any special screws, cover caps, alternative fastening methods, or craftsmanship tips that actually work in practice and remain stable?Interesting question. In principle, with Ikea furniture like the Hemnes, the visible screws are often necessary to ensure the intended stability and ease of assembly.
There are cover caps available, but these only conceal the screw heads, not the fastening method itself.
Trying to avoid visible screws entirely usually results in significantly more effort and can cause stability issues.
Alternative fastenings like dowels or connector fittings are provided, but due to the construction, the assembly is hardly ever completely hidden.
If appearance is important to you, you might want to focus on a combination of hidden dowels at tension points and decorative covers. Otherwise, the furniture would practically need to be completely redesigned to achieve invisible assembly.
BAUEVA schrieb:
Alternative fasteners like anchors or connection brackets are planned, but due to the construction, the material package will hardly ever be completely hidden.True, but honestly, why hide the Hemnes-type with all its charming screws? They’re a bit like small tattoos on furniture: they show that everything belongs together. 😉
If you really want to conceal the screws, you can use color-matched caps. They come in wood tones close to the Hemnes color.
Just snap them on, and it looks much tidier. Add a few delicate mouldings or covers, and the screws barely stand out anymore.
In my opinion, this is almost the best mix of sturdy and aesthetic without too much DIY.
Draro schrieb:
My concern is not only the visual aspect, meaning that the furniture should look as clean as possible without visible screws, but also whether there are practical solutions to avoid or at least cover the traditional screw system.It is important to respect the original construction, especially with IKEA furniture like the Hemnes, in order to maintain stability.
A practical solution is to cover screw holes with matching plastic or wooden caps designed specifically for IKEA screws. If a uniform look is desired, these caps can be lightly sanded and treated to adjust the color.
Sometimes simply refinishing the edges with thin veneer strips or edge banding profiles can visually conceal existing fasteners without affecting functionality.
This way, the integrity of the assembly is preserved while the piece appears tidier. Completely hiding screws without extensive custom modifications is technically difficult to achieve.
