ᐅ Is there a way to equip IKEA BESTA units with soft-close dampers?
Created on: 15 Dec 2022 10:27
Pese51Hello everyone,
I have a somewhat specific question that might also be interesting for other IKEA Besta users: Is there a way to equip IKEA BESTA furniture with dampers to soften the door closing?
I’m aware that the doors on the BESTA series tend to close quite quickly and loudly, which can be disturbing, especially in a quiet living environment.
My idea is whether and how it’s possible to retrofit dampers (hydraulic or soft-close mechanisms) without damaging the original furniture structure or having to do complicated modifications.
Does anyone have experience with this, either using accessories from IKEA itself or third-party solutions? Maybe there are special tips or practical modifications?
I’m looking forward to your opinions and advice!
Good question, Pese51!
There are definitely ways to retrofit IKEA BESTA furniture with soft-close dampers, but it’s not as simple as it sounds. Here’s a brief overview:
- First, you need to decide whether you want hinges with built-in soft-close functionality or separate door dampers.
- Many people use so-called “clip-on” soft-close hinges that can be directly attached to the IKEA BESTA doors. These have the advantage of not requiring major modifications to the furniture.
- A tip: The hinges need to match the existing drill holes. BESTA uses standard drillings, so many soft-close hinges from third-party manufacturers are compatible.
- However, if you want to install hydraulic dampers mounted on the outside or inside, you often have to drill or glue, which could damage the furniture.
- When installing, it’s essential to ensure the dampers fit precisely; otherwise, the doors may not close properly or could sag.
In summary: Yes, there are solutions, mainly soft-close hinges as replacements for the originals. Retrofitting classic dampers afterward is more complicated and usually not recommended.
If you like, I can provide you with the exact model names that are often compatible.
KUDAISY schrieb:
When installing, you should definitely make sure the dampers fit exactly, otherwise the doors may not close properly or could sag.This is an important point, which I would like to add a critical note to: There is indeed no official IKEA solution, so any simple retrofit is always a compromise. If someone tries to just attach hydraulic dampers without considering the load on the door and side panels, they risk damaging the construction over time.
Also: Almost all DIY solutions that add dampers work technically, but they are often visible and not very elegant or harmonious with the design. That is certainly a matter of taste, but should be kept in mind.
My conclusion: When it comes to BESTA, the most practical approach is to replace the hinges with soft-close models, which provide a noticeably smoother closing experience with minimal visual changes to the furniture.
A general question for Pese51: How important is the appearance of the solution to you? And do you want to keep it as reversible as possible?
Tinaneo schrieb:
My conclusion: When it comes to BESTA, the most practical solution is to replace the hinges with soft-close models, which give the furniture a noticeably smoother closing action with minimal visual changes.I completely agree with this.
I installed soft-close hinges on my BESTA units some time ago myself. There are various models available on the market that fit perfectly.
Important points:
- The hinges must be compatible with the drilling pattern (usually a 35mm standard),
- Installation can be done easily with a screwdriver, no special skills required,
- You should consider how strong the damper mechanism needs to be; some models are too weak or too strong for your particular door.
Also: If you don’t want soft-close hinges but really want to add dampers, I would recommend involving a professional or a carpentry workshop. DIY installation can be tricky.
If you need more details, feel free to ask, I’m happy to help!
