Hello everyone, I recently bought some pieces of furniture from the popular IKEA Malm series and am wondering if there are any specific care instructions or recommendations for these items. I want to make sure I don’t accidentally damage the surfaces when cleaning or protecting them. I’m especially interested in which cleaning products are suitable, how to avoid scratches, and if there are any particular treatments for the surface that go beyond standard furniture care. Maybe there are official guidelines from IKEA or proven tips from the community? I look forward to your experiences and suggestions!
Basically, IKEA Malm furniture has a melamine coating, which makes it relatively easy to maintain. I would recommend cleaning it with a damp, soft cloth and a mild dish soap solution. Harsh cleaning agents or abrasive sponges can damage the surface. It is also important not to let larger amounts of water sit on it to prevent swelling. I have personally reviewed the official care instructions from IKEA, and they basically say the same.
Another point is to avoid direct heat sources and to wipe up any spills immediately. This helps prevent scratches and stains on the surface.
I think it’s good that some basic tips have already been shared, but I would like to critically examine how reliable these recommendations really are.
That sounds plausible, but what evidence or experience supports this advice? I am interested in whether regular light cleaning with various products causes no long-term damage to melamine. Aren’t these pieces of furniture also made from materials designed to withstand greater stress?
What about grease stains or the removal of stubborn dirt? A more nuanced assessment on this would be helpful.
olivernu schrieb:
I would recommend using a damp, soft cloth with a mild detergent solution for cleaning. Harsh cleaning agents or abrasive sponges can damage the surface.
For clarification: IKEA’s Malm series is known for its melamine resin-coated surface. This coating is generally resistant to moisture and many household chemicals, which makes maintenance easier.
According to the manufacturer, aggressive or abrasive cleaning agents should be avoided, as they can cause long-term damage such as dulling of the surface or microcracks.
To remove grease stains, a mild solvent like isopropanol diluted with water is recommended, but only in small amounts and wiped off immediately. It is important to thoroughly dry the furniture after cleaning to prevent any potential moisture absorption at the edges.
In summary: normal household cleaning with mild dish soap is sufficient, while localized heavier soiling requires special care.
BAUEVA schrieb:
I am interested in whether regular light cleaning with different products causes any long-term damage to the melamine.
It’s great to see how quickly you’re already taking it apart 😉! I’ve always cleaned my Malm tables with a soft, slightly damp microfiber cloth – works perfectly, and the pieces look like new.
Regarding scratches: I’ve heard it’s best to use coasters or felt pads under items that are moved frequently. This helps prevent minor scratches. Also, avoid sharp-edged objects that can easily leave marks.
And very important: no abrasive sponges! They can scratch the surface, even if it’s just small dust particles. So it’s better to clean gently. 🙂
rumar schrieb:
... which cleaning products are suitable, how to avoid scratches, and whether there are any special considerations for treating the surface ...
