ᐅ Is the plug-in system used in KALLAX designed for frequent assembly and disassembly?
Created on: 10 Apr 2019 10:17
BenpaulHello everyone,
I am currently looking into whether the plug-in system of the IKEA KALLAX shelves is generally designed to withstand frequent assembly and disassembly. I am particularly interested in how durable the plastic joints and locking tabs are if the shelf is taken apart and put back together every few months, for example, during moves or when reorganizing an apartment.
Has anyone had experience with whether the material wears out quickly or if the stability suffers as a result? Or are these connections mainly designed for a secure fit without many repetitions? I would appreciate any responses, especially if you have practical insights or comparisons to other shelving systems.
Hey Benpaul!!!
The KALLAX is really practical! I've rebuilt it several times already, and the plug-in system stays surprisingly secure! 🙂 Of course, if you take it apart every few months, you can notice that the corners aren’t quite as tight anymore, but nothing that affects its usability. Just be a bit careful when assembling, and everything stays stable. Furniture like this also makes moving much easier! Good luck with your project!!
INGRID34 schrieb:
Frequent disassembly can weaken the joints, especially the plastic locking tabs.Thanks for the insight. What do you mean by the fit – do the connections loosen over time, or do parts eventually break off?
GLALEO schrieb:
In my experience, it holds surprisingly well, but you can tell that the corners aren’t quite as tight anymore.That’s somewhat reassuring, but would it make sense to have spare parts or reinforcements for frequent use? Is there a way to strengthen the joint? I’m especially interested if the locking system is standardized enough to be compatible with third-party components.
The KALLAX plug-in system was primarily designed for a stable, one-time assembly. The plastic plug connections tend to show wear on the tabs with frequent disassembly and reassembly, which can lead to a loose fit. Breakage is less common but not impossible.
Replacement parts in the form of individual plug tabs are not part of IKEA’s standard offer, but there are aftermarket or universal connectors available on the market that can be used for reinforcement. Compatibility with third-party parts is limited due to tight dimensions and tolerances, and because the system is not designed to be modular.
Hello Benpaul,
I have assembled and disassembled KALLAX shelves several times, as I have used them for different purposes. The snap-fit connections are sturdy enough for occasional disassembly but not for very frequent reassembly, like on a monthly basis or more often.
Plastic snap systems weaken over time due to stress and material fatigue. The locking tabs become slightly softer with each assembly and can wear out, which may cause the shelves to become unstable.
One way to reinforce them would be to drill additional small wooden dowels and mechanically secure the joints. Although this is not part of the original design, it can improve durability.
If you really plan to take the shelves apart and put them back together frequently, an alternative with screw connections might be more suitable, even though it takes a bit longer to assemble.
I hope this helps! 🙂
