ᐅ Is it possible to cheaply expand Ikea PLATSA units using leftover wood?
Created on: 2 May 2021 09:13
FEJUDAH
I am considering supplementing my Ikea Platsa system with leftover wood to save costs while adding a personal touch. My main question is: Is it practical and, above all, cost-effective to expand or modify PLATSA components using self-cut or leftover wood? I am particularly interested in how well the material Ikea uses can be combined with other types of wood, whether the stability is affected, and which tools or methods are recommended when planning such combinations.
Has anyone had experience with this and can provide insights or advice? I want to build affordably but also maintain quality.
Grace schrieb:
Offcuts are often solid wood or plywood. The surfaces and density usually varyI find this more problematic than many others here. Ignoring the material density and the different expansion behavior with moisture can lead to stress and warping over time.
I also wonder how many manage to maintain the necessary tolerances within millimeters, as required by Platsa. This can quickly result in stiff doors or even damage to the finish.
Anyone looking to cut costs should be truly aware of the risks.
JEREMIAH382 May 2021 20:06I understand the intention well – I also struggled to expand my PLATSA affordably. It feels kind of satisfying to give your own furniture a personal touch.
But especially in the beginning, I was unsure if I was making mistakes. Sometimes it takes courage to just experiment and build small modules before tackling the entire system.
If you like, I’m happy to help with questions about materials or planning.
Gregory schrieb:
- Dimensions: The construction method of PLATSA is based on fixed modular measurements. Your leftover wood must precisely match these dimensions to fit seamlessly.That’s what I was afraid of. Are there any practical tips or experience on how to best maintain these modular measurements when working with reclaimed wood? Do you have to completely recut it, or can you carefully trim it to fit?
I want to minimize waste as much as possible and would appreciate advice on how to best adjust leftover wood for PLATSA.
FEJUDAH schrieb:
Are there any tips or practical experience for maintaining these grid measurements when working with reclaimed wood?The most important thing is a reliable measuring tool – ideally a combination of a folding rule or tape measure and a table saw with a fence to achieve straight cuts.
If you have leftover wood that doesn’t fit exactly, you can usually make quite clean rip cuts with a circular saw and a guide rail. “Trimming to fit” works but is only practical for adjustments of a few millimeters and should be done very carefully.
Make sure to consider the cutting direction and grain orientation to prevent edges from fraying or splintering. Edge banding with two-component adhesive can also help improve the appearance.
The effort is worthwhile if you want a good and stable addition.
FEJUDAH schrieb:
I want to minimize waste and need tips on how to best match leftover wood to PLATSA.From my own experience: Plan everything digitally or on paper before you start. Write down the exact dimensions of the PLATSA modules you want to add.
When you have a measurement, consider whether you need to cut the leftover wood in one step or multiple steps. I started with small trim pieces that I used as panels – the tolerance is greater there.
You can also work a bit with particleboard or MDF sheets, which are cheaper and easier to work with, to create fitting pieces.
Important: If you want to work flush with edges, measure multiple times and proceed step by step.
