ᐅ Is it possible to change the color of IKEA PLATSA furniture?
Created on: 2 Oct 2018 19:43
lokyan
lokyan
2 Oct 2018 19:43
I recently bought some IKEA Platsa furniture for my living room and am wondering if it is possible to change the color of the furniture afterward.
Since the Platsa series mainly consists of frames and fronts, I think there might be options to paint, coat, or apply adhesive vinyl films to the surfaces. However, I am uncertain whether the material allows this without quality loss or if the furniture might lose stability or aesthetic appeal as a result.
I am especially interested if anyone has practical experience with whether and how the color of the Platsa pieces can be changed properly without it looking unprofessional or affecting their functionality. Are there important things to consider, such as surface preparation, special paints, or adhesives?
I look forward to your tips and experiences!
kla65
2 Oct 2018 20:37
You can definitely paint or apply a film to PLATSA furniture.
- Clean and sand the surface thoroughly
- Use a primer suitable for plastic
- Apply thin layers of paint
The material is usually MDF with a plastic coating, so proper preparation is important. Stability is not affected.
PLOMA
3 Oct 2018 07:12
Regarding changing the color of IKEA PLATSA furniture:
The PLATSA components are mostly made of melamine resin-coated particleboard (or MDF for some fronts) with a smooth, relatively durable surface. This coating offers some advantages but also makes painting or applying adhesive films more challenging, as paints and adhesives often have reduced adhesion.
If you want to change the color, the following steps should be considered first:
- Cleaning: Thoroughly degrease the surface (e.g., with alcohol or a special cleaner) to remove dust, grease, and silicones.
- Sanding: Lightly sand with fine-grit sandpaper (around 240 grit) to roughen the surface.
- Priming: Apply a plastic primer (e.g., adhesion promoter) suitable for melamine and similar surfaces to ensure the paint adheres properly.
- Painting: Acrylic or two-component (2K) paints can be used, applying thin, even coats.
Adhesive films (e.g., special furniture foils) also work well but require an especially smooth and clean surface. Edge sealing is important here, as films tend to lift at the edges.
Important: Painting directly without pretreatment usually results in poor outcomes. Without priming, the paint can peel or become uneven. The material thickness of the carcasses must also be considered—excessive sanding or mechanical processing can affect stability.
Finally, a question: Are you more interested in the fronts or the carcass frames? This significantly affects the method and effort required.
praWarre69
4 Oct 2018 09:06
PLOMA schrieb:
Important: Painting directly without any pretreatment usually results in poor quality.
I can only agree with that! I once tried to spruce up a PLATSA dresser with spray paint – and the result was really bad because I didn’t think about preparing the surface at all.
My advice: Patience and a bit of fine workmanship go a long way. It’s best to sand, prime, then lightly sand again before painting.
Afterwards, I sealed the fronts with a matte clear coat, and now it looks really neat and professional.
If you’re not confident with painting, you can also try window film or furniture wraps – I even secured the film at some edges with clear craft glue, which holds up great.
Just be careful on heavily used surfaces, as films can wear out faster. Overall: It works, but pay attention to the details!
