ᐅ Is it possible to assemble Ikea Platsa furniture without using screws?
Created on: 4 Aug 2020 18:37
Rronje
Rronje
4 Aug 2020 18:37
I am currently faced with the task of assembling an Ikea Platsa furniture unit, but I am unsure whether it is possible to assemble it entirely without using the supplied screws.
I am wondering if there are practical alternatives that allow for a stable and secure construction without the usual screws – perhaps using snap-fit joints, clips, or other mechanisms?
My main concern is the stability and long-term use, as the furniture will also bear some load. Does anyone have experience or recommendations on how to assemble the Platsa system without screws, or whether it might even be advisable to avoid them altogether?
Thanks in advance for your tips and opinions!
Muso4
4 Aug 2020 19:12
Rronje schrieb:
I am currently faced with the task of assembling an Ikea Platsa piece of furniture, but I am unsure whether it can be put together entirely without using the supplied screws.
To be honest? Trying to do it without screws is likely to be a disappointing experiment. The screws aren’t there by chance; they form the framework that holds the cabinet together.
Rronje schrieb:
I’m wondering if there are practical alternatives that allow for a stable and secure construction without the usual screws.
Practical doesn’t always mean safe or durable. Sure, you could use glue, wood connectors, or brackets, but then it’s no longer a “Platsa” piece—it becomes a custom build that certainly voids the warranty and compromises stability.
If you ask me, the furniture market depends on the screw-based concept—that’s essentially the foundation of what Ikea flat-pack furniture is about. Screws are the backbone, not a gimmick. Anything else is, to put it bluntly, questionable from a moral standpoint.
Jeanbar
5 Aug 2020 07:03
Hello Rronje,
I understand that you are looking for a screw-free solution, perhaps for aesthetic or practical reasons. However, the Ikea Platsa series is originally designed so that the fasteners, especially screws and connectors, ensure the modular structure is secure and durable.
In principle, there are alternatives for furniture such as locking systems or tongue-and-groove joints, but these are not intended for Platsa.
It is also important to note that the screws additionally help to stabilize the furniture against lateral forces – this is especially crucial for taller cabinets to ensure safe standing. Without screws, I personally would not expect long-term stability.
If you are concerned about assembly, I recommend disguising the screws with some Teflon tape or special caps. Or, for a less invasive setup, tightening the screws in the pre-drilled holes is probably the best compromise between stability and appearance.
I hope this helps you with your decision!
Luke44
5 Aug 2020 08:29
Of course, you can try building without screws, but it won't be stable.
If you really don’t want to use screws, then only a completely different system will work; Platsa is not designed for that.
JONKO
6 Aug 2020 10:42
I just wanted to quickly share that I tried to assemble a Platsa shelving unit without using any screws – simply by slotting the parts together and using clamps.
It held up for a few days, but it started to wobble pretty soon after. Honestly, I was quite frustrated because I had hoped to avoid dealing with screws altogether.
I completely agree with that. Especially if you have kids at home or need to move the furniture frequently, I wouldn’t want to give up the stability that screws provide.
Maybe you can find a way to make the screws less visible or reach a compromise, Rronje. But I would strongly advise against using the Platsa system without any screws at all.
