ᐅ Is it possible to assemble IKEA Metod kitchen units yourself without any problems, even in small rooms?
Created on: 9 Mar 2024 08:13
Neocorin
Hello everyone, I would like to start a discussion on the topic: "Is it also possible to assemble IKEA Metod easily in small rooms?"
I am planning to get the Metod kitchen system, but my kitchen space is quite compact at around 7 sqm (75 sq ft). I am curious whether the installation becomes particularly challenging when the area is tight. What difficulties can be expected when building in small rooms, for example, due to limited space for handling the individual parts or aligning them?
Does anyone have experience with strategies to make self-assembly in a small space as smooth and error-free as possible? Are there tips beyond the standard instructions, especially considering the limited room? I would appreciate detailed insights, as superficial answers won’t be very helpful here.
On the topic "Is self-assembly of IKEA Metod also feasible in small rooms?": From my perspective, the assembly instructions for Metod are clearly structured. You should create enough space on the floor before starting assembly. If spreading out the parts in the room is not possible, find a place outside the room. Organizing tools and parts beforehand helps a lot.
Joe52 schrieb:
I experienced this myself when I wanted to build my kitchen in a small apartment. What helped me a lot was constantly reminding myself that patience is key – and that it’s perfectly fine to spread the assembly over several days.Exactly! A bit of calmness makes all the difference. The IKEA method isn’t rocket science, but tightly fitted kitchen cabinets can really test your nerves. I also recommend listening to music or a podcast; it can really help to relax. 😊
Neocorin schrieb:
I’m curious whether the installation becomes particularly tricky when working in a confined space. What challenges can be expected when assembling in small rooms, for example due to limited space for handling individual parts or aligning them?In practical terms, the main challenges are as follows:
- Freedom of movement: Large components are often difficult to maneuver and quickly become cumbersome in a small area.
- Clearance for alignment: For precise adjustment, a level surface with some space around it is recommended.
- Tool and material management: A small area usually doesn’t provide enough room to lay everything out neatly.
Therefore, it is advisable to carry out thorough preparation in a larger space and perform only the final assembly step in the tight kitchen area.
