Is a trap necessary in a paved garage? The water can also seep through the joints. And with a trap in the middle of the garage, a slope towards the trap must be created from every side, whereas without a trap, paving would be simpler, as a slope towards the garage door would be sufficient (the area in front of the garage also slopes downward). Thank you very much
as far as I know, you are not allowed to have a drain in the garage. In case of an oil leak, the oil would otherwise flow uncontrolled into the sewage system.
What water do you want to let infiltrate into the ground? The water you bring into the garage with your car when it rains?
Otherwise, it probably also depends on your subsoil and your paving.
