ᐅ Joint with gravel filler for paved garage driveway
Created on: 18 Jan 2026 23:38
Sockeldichtung
Sockeldichtung
18 Jan 2026 23:38
Good evening,
Our landscaper paved our driveway up to the garage with a gravel joint about 3 - 4 cm (1.2 - 1.6 inches) wide, as shown in the picture. This is not really ideal because some gravel keeps coming out of the joint. Also, the loose gravel probably won’t create enough lateral pressure in the long term, which may cause the stones to shift.
How can this be improved? The joint should remain permeable because the pavement is approximately level with the garage floor. Our idea is to remove about 2 - 3 cm (0.8 - 1.2 inches) of gravel from the joint and fill it with drainable concrete. What do you think?
Sockeldichtung
1 Feb 2026 21:15
Does nobody have an opinion on this idea or an alternative suggestion?
MachsSelbst
1 Feb 2026 23:19
What is supposed to drain away there? If the paving next to the garage has a slope of at least 2%, then you don’t need that strip. In that case, lift the stones and lay the paving up to the garage with joint width. Otherwise, a drainage channel is required there, and the paving should be laid normally with joint spacing along it.
jehd
2 Feb 2026 07:19
At this spot, an epoxy resin joint filler was used. It is significantly more expensive than regular grouting, but since it is only this joint (the rest of the surface has standard joints), it has held up very well for about 10 years without crumbling. Ours is approximately 2cm (0.8 inches) wide.
Sockeldichtung
9 Feb 2026 00:54
The top edge of the pavement is approximately level with the garage floor and then slopes downward at a 2 - 3% gradient. In heavy rain with wind blowing towards the garage, water would probably still be forced into the garage if the joint were completely sealed. Therefore, in my case, epoxy resin is probably not ideal, but I will keep it in mind.
Installing a channel drain now would be quite labor-intensive. Is there any reason not to consider drainage mortar?
tomtom799 Feb 2026 12:21
The mortar will not lift.
This should have been planned in advance. If it couldn’t be done differently, the joint could have been brought forward or simply larger paving stones could have been placed exactly at the edge.
What you can try is using gravel stabilizer to seal the joint.
